Old 08-17-2008, 04:48 PM
xPrestigeRGAx  is offline
Posts: 80  -  iTrader: (0)
Help! pickups sound weak. wiring problem?
I just got my SH-6 Duncan Distortion and Gibson 496R installed in my guitar. they sound very weak for such very high output pickups. This is how they're wired. i have a volume and tone knob and 5 way switch. They are wired for humbuckers only.
Position 1- SH-6 hum mode
Position 2-Sh-6 hum mode
Position 3- 496R and Sh-6 hum mode
Position 4-496R hum mode
Position 5-496R hum mode.
Anyone, please let me know if maybe theres a wiring problem that sptil the signal makign them sound very weak before i rip em out and put active emgs or SD Blackouts. thank you
Old 08-18-2008, 03:54 AM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Re: Help! pickups sound weak. wiring problem?
Sounds like a wiring fault... check your wiring again. Either that or there may be some dodgy solder joints.
'87
Old 09-16-2008, 08:24 AM
plugger  is offline
Posts: 112  -  iTrader: (0)
Try wiring each pickup (one at a time) directly to the output jack, bypassing all switches, pots, other wiring. Is the output now significantly higher?
Old 09-18-2008, 07:38 PM
D1m3b4g2  is offline
Posts: 269  -  iTrader: (7)
Images: 2
Reviews: 21
Without meaning to sound patronising here my mate had this issue and it was simply the fact the pickups needed raising nearer to the strings. If you've already done that ignore me!
Old 09-18-2008, 09:33 PM
fretboardpyro  is offline
Posts: 311  -  iTrader: (0)
Reviews: 12
could very well be wired in parallel or out of phase.
wiring duncan sh-6
Help! Pickups sound weak? Is it just my setup? jbandy10 Tech: Setup, Repairs and Mods 15 04-27-2008 08:13 PM
Coil tap - weak clean sound? aenis JS (Satriani Model) Ibanez Guitars 5 06-27-2007 09:19 PM
Computer sound problem Myst and rain Off-topic / Miscellaneous 1 03-16-2007 03:20 PM
Pickups and Wiring for a Brian May sound? marianozz Pickups & wiring 2 01-16-2007 08:42 PM
Does this sound like a tube problem to you? Al M Gear and Equipment 5 07-28-2004 07:30 PM
