Hi i got an ibz rg470 with tone zone in the bridge , ibz inf in the middle and
air norton in the neck with 5 way switch, i want to replace the switch for a fender type 3 way switch and eliminate the single coil and use only the humbuckers in a configuration:
pos. 1 bridge
pos. 2
inner coils
pos. 3 neck
how i got to do the wiring, i search in the web but i only found a different position 2 with the two humbuckers at the same time or with a different switch i think is a dpdt switch and mine is a fender type 3 way switch.
Thanx
