Old 12-23-2008, 03:27 PM
rublalup  is offline
Posts: 98  -  iTrader: (0)
Images: 5
help with coil tap
hi,
i got my american strat (SSS) with 2 air norton (n,b) and a fast track 1.
the sound is great and i´m now thinking in changing the volume pot with a a push pull to coil tap all pickups and have a semi-singlecoil configuration.
something like:
when push pull down:
1-full bridge
2-full bridge + full midle
3-full midle
4-full midle + full neck
5-full neck
(this is the actual configuration with the stock 5 way switch)
whe pull up the push-pull:
1-1 coil of bridge pu
2-1 coil of bridge + 1 coil from midle
3-1 coil from mid
4-1 coil from midle + 1 coil from neck
5-1 coil from neck pu
is this posible?......any diagram?
thanks a lot.
Old 12-23-2008, 04:31 PM
rublalup  is offline
Images: 5
Re: help with coil tap
or instead the coil split should i add a parallel option?....or both?
push/pull or mini toggle?....
i love the tone i got now and it fits my style and genre perfect but also like to recover a cleaner sound for some recording stuff.
Old 12-23-2008, 05:31 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
You could coil-tap two pickups with a single push-pull switch, but not all three. A parallel switch could only be done on one of the pickups with a single push-pull. Personally, I would just add a neck parallel option, but that depends on your style and needs. In addition, I find Fender knobs to be a bit difficult to grab for push-pull operation so I'd probably go with a mini-toggle, but again, that's just my preference.
Old 12-23-2008, 05:39 PM
rublalup  is offline
Images: 5
thanks...
yup, i was thinking that if it cant be done i just coil tap (or set to parallel) the neck and midle pu´s...
you have a diagram or something?
Old 12-26-2008, 01:35 PM
rublalup  is offline
Images: 5
anybody?
coil tap or parallel? anyone tried that on this kind of pu´s?
i also could use a mini toggle (i have an on/on) but really need the diagram...
thanks
coil tap
!!! COIL TAP JEM !!! HELP!! mooro Pickups & wiring 2 07-18-2008 03:38 AM
Sustainer - Replacing Dummy Coil with Single Coil? F.P.R.O. Pickups & wiring 7 09-12-2007 03:33 AM
Coil Tap!! Acid Rain Tech: Setup, Repairs and Mods 22 07-15-2005 08:04 PM
coil tap woodros Pickups & wiring 8 05-01-2004 05:04 PM
JS- 10's and coil tap. JayRobIBZ JS (Satriani Model) Ibanez Guitars 2 08-14-2002 03:58 PM
