Originally Posted by frankfalbo
No problem. You just have to reverse the two black wires on the neck pickup side of the switch. It's all in that upper quadrant. So the little black jumper that goes from pin 2 (neck side) to pin 4 (bridge side) needs to go to pin 4 (neck side) and leave the bridge side alone. Then the jumper that goes from pin 4 (neck side) to the "other" pin 4  needs to go over to pin 2.
Somehow I knew it would be frankfalbo to reply... Thanks!
I have an additional ?...
From what you describe it appear that the four outer-most lugs, where the white and black wires from the pups go and the link that sends the signal to the pot are not counted. Am I correct?
The black jumper you are refering to, is it the one that goes to the back of the pot?
If I rotate the picture in the diagram so that it's vertical, I get this:
Neck hot goes to lugs 8, 9 and 10 on the left side
Bridge hot goes to 6,7 and 8 on right side
Could you re-iterate what to change as I'm having trouble picturing what you explained...
Sorry to be brain-dead...
If you're ever in Vancouver, I'll buy you a beer...
Thanks!
