Hi
I'm trying to upgrade my ibanez RG with two evolutions and HS-2 in the middle because i'm a great Steve Vai fan and I found this on the FAQ section of the Dimarzio website:
“I want to emulate the Vai
pickup combination. What kind of single coil should I use?
Evolution and JEM single-coils are only available on the
Ibanez JEM and are not sold through retail channels.
You can achieve a similar result by wiring an HS-2™ for single-coil operation only: black wire hot,
red and bare wires ground, green and white not connected.”
So i started to make the wiring following the normal diagram diagram for Jem (
http://www.dimarzio.com/media/diagrams/C.pdf) and I also used all dimarzio hardware, but IT DOESN’T WORK.
The Sound that I obtained was a very clean and powerless in all pick ups and a I only have this sound with the “metal zone” and with another normal effect I can’t obtain anything.
Can anyone tell me my mistake about this wiring??
Please Help me... I’m mad about this.
