Old 09-28-2009, 04:38 PM
Captaincohny  is offline
Posts: 8  -  iTrader: (0)
Help with pickup swap
I'm having alot of trouble wiring a dimarzio evolution into the bridge position of my RG3EX1 guitar. I've looked at every wiring diagram I can find and I still don't know where to solder the different wires. My stock pickup has only a white, red, and an uncovered wire. The evo has a red, green, black, white, and uncovered wire. Its a standard HH setup with 1 volume and one tone. Here is a picture.
Edit: never mind I apparently can't.
Can someone help me out. The dimarzio wiring diagram has some switch in it I've never seen before.
Old 09-28-2009, 05:06 PM
Re: Help with pickup swap
Nobody?
I think I'll just wing it.
Old 09-28-2009, 05:34 PM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Can't find a diagram for the rg3, Usually for the Evo, the red is the signal output the black and white are soldered together as the coil tap and the green is the ground, I guess the uncovered wire is the ground on the one you have and either the red or white is the signal with the other being the tap wire, have a go red for red and black/white for white and see if it's ok, if not swap the red and black/white...
Jim
Old 09-28-2009, 07:13 PM
MarkE  is offline
Posts: 469  -  iTrader: (0)
Reviews: 15
Jim
Yup, that's right.
Bare and green together, to where the bare wire was
Black and white together, to where the white wire was
Red to where the red wire was
Old 09-29-2009, 05:01 AM
Marcel-JS-build  is offline
Posts: 7  -  iTrader: (0)
Images: 1
Look here.....
some options for wiring... choose what you want.
seymourduncan.com/support/wiring-diagrams
Pickup Swap Alopikal Pickups & wiring 2 04-26-2009 03:32 PM
Pickup swap for RG2020xtb pierce34celtic J-Custom, USA Custom & Prestige Ibanez Guitars 20 06-27-2007 10:05 AM
Pickup swap video how to? 70Seven Pickups & wiring 3 05-15-2007 10:32 AM
Pickup swap. All eyes here! pinto79 Other Ibanez Guitars (including Premiums) 0 12-27-2005 05:30 AM
Just did a Pickup swap, what to look for? Triangle Pickups & wiring 4 06-09-2002 01:08 PM
