Old 02-08-2013, 01:29 PM
Superlead777  is offline
Posts: 36  -  iTrader: (0)
Help with wiring.....
I have rewire my USRG30 to this diagram and the Tone Zone still sounds like a weak Tele. Not what I what.I want full blown humbucker mode.Any idea(s) what the problem could be?
Thanks for your help.
Old 02-12-2013, 11:30 AM
Re: Help with wiring.....
Anyone?
Old 02-12-2013, 04:02 PM
LonePhantom  is offline
Posts: 7,198  -  iTrader: (8)
Reviews: 120
Sounds like you've only wired one coil to the switch position for the bridge. That image you've attached is way to small to see clearly, but make sure you've wired the red wire on the Tone Zone to the bridge humbucker position on the switch.
Old 02-12-2013, 10:24 PM
This might help...I've wired this exactly as diagramed......
Old 02-12-2013, 11:58 PM
Reviews: 120
Well something is not wired correctly. Made you've got a cold solder joint. To over the solder joints and reheat and make sure they cool with a shiny luster. If its dull then its a bad joint.
diagram, f.aq., pickup help, usrg30
Ibanez Wiring vs. DiMarzio Wiring HSH MattPM Pickups & wiring 34 06-06-2012 03:49 PM
Need Help! Wiring a Jem 77V, 3 Humbuckers wiring diagram Kronosa Pickups & wiring 0 02-09-2012 06:21 PM
JS1 ('90/'91) Volume Pot Wiring / Wiring Model? guitarboy JS (Satriani Model) Ibanez Guitars 0 01-14-2007 04:31 AM
Re-Wiring Question - Ha, semi-related to the "Wiring Questio Two hands31 Tech: Setup, Repairs and Mods 19 01-03-2002 06:26 PM
WIRING HELP NEEDED - wiring on RG aerocol Tech: Setup, Repairs and Mods 6 07-17-2001 01:02 PM
