Re: How could I wire this if possible?
Here's an option if you don't use the tone knob(I never do so its a wasted knob normally). Unwire the tone knob but leave the case grounded. Take the 2 wires of the humbucker that would get hooked together in a standard humbucking setup and solder them to the center lug on the tone pot. Now when you back the tone knob down, you will gradually bypass one coil(tone all the way off gives straight single coil). If you wire a phase switch before the tone control, you can switch between each coil when in single mode.
