Re: How much should I expect to pay for a full EMG set up
You can usually find space in 'most' guitars to put the battery for your EMG's without having to route an extra cavity.
Everything you'll need(pots,battery clip,screws,pickup leads etc.) comes with the pickups so you'll probably just be looking at the cost of the pickups and maybe a little bit of extra pickup wire (depending on the guitar).
They're probably the easiest pickups as far as fitting goes. I had no problem with them (so you definitely shouldn't,lol).
