Old 02-20-2009, 07:30 PM
bhuether  is offline
Posts: 60  -  iTrader: (1)
How to wire tone/volume bypass?
I have a two humbucker guitar (both Dimarzio). It has a 4 pole, 3 way on-on-on pickup selector switch (like the Dimarzio EP1111). Options currently are
1 bridge
2 inner coils of both
3 neck
I just ordered two push pull pots. I want one to split the coils of the neck and bridge. One pot can't do this independantly so they would both be switched at same time. So with the push/pull engaged, it would be
1 bridge inner (or outer depending on what I decide)
2 inner coils of both (so this position wouldn't really change)
3 neck inner (or outer depending on what I decide)
And then with the other push/pull, I want to bypass the tone and volume pot and send the bridge pickup directly to the output.
Any idea how I would wire this up?
thanks,
brian
Old 02-21-2009, 02:41 AM
bhuether  is offline
Re: How to wire tone/volume bypass?
Ok, I think I figured something out.
Check this out:
Push/pull 1 is a coil cut switch that cuts both pickups simultaneously. The 4 pole 3 way switch is what came with the guitar.
This should work as
Push/pull 1 down*
1 Bridge series
2 Bridge series parallel w/ neck series
3 Neck Series
Push/pull 1 up*
1 Bridge north coil
2 Bridge north coil parallel w/ neck south coil
3 Neck south coil
And then push/pull 2 when pulled up should bypass the volume and tone controls sending the pickup outputs for each of the settings above straight to the output jack.
But I am not sure about this. Can anyone tell me if this will work?
thanks,
brian
Tone/Volume Pot Help Thrash Pickups & wiring 3 01-11-2007 02:18 PM
Anyone bypass the tone knob? Rotti Pickups & wiring 15 12-22-2006 06:10 PM
Busted tone pot bypass surgery. Leader Pickups & wiring 11 03-15-2006 09:57 PM
Bypass Tone Pot with Fred? pedalinbob Pickups & wiring 2 04-09-2005 12:37 PM
Wire a Toggle instead of a Volume pot? MagicAxe Pickups & wiring 4 05-27-2004 12:48 PM
