Pickups & wiring
HS-2 seems REALLY quiet
Pickups & wiring
03-19-2008, 12:53 PM
nullsys
Posts: 31 - iTrader: (
Hi,
I have an RG1570, from around 2003 and I just swapped out my standard V7, S1 and V8 for: Tone Zone, HS-2 and a
Air Norton
Now, the two humbuckers sound great, but when I switch into positions 2 and 4, which is supposed to have half bucker+single it sounds VERY tinny, looses its volume alot and makes a slight buzz sound when I pick hard on the
high strings
. It also looses its bottom end.
The middle pickup sounds great by itself.
I presume I have wired this wrong.
: Took out old pickups
: Connected BLACK+WHITE together and GREEN+BARE together on all three DiMarzios
: Put them back in as the others were setup.
Have I done something wrong?
If I tap the hums with a bit of metal, I can tell the right coils are working along with the middle, but the sound is so thing and squeeky.
Can anyone help?
PS im a lefty! Forgot to mention that.
nullsys
Find all posts by nullsys
03-19-2008, 01:46 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: HS-2 seems REALLY quiet
Yup. HS-2 is really quiet. I haven't found a way to make the HS-2 or HS-3 sound loud enough to match up with powerful humbuckers.
jaxadam
Find all posts by jaxadam
03-19-2008, 02:37 PM
nullsys
Ah right, there we go then lol.
It really is a HUGE difference, when you have a slight crunch on your hums, you can switch to a 2, or ,4 position and you get a clean sound, handy sometimes I guess.
Whats the Blue series like?
I might install a JEM, like PG.
Think that would work in the center?
nullsys
03-19-2008, 02:48 PM
jaxadam
Classified Watchdog
I personally don't like HS-2 or HS-3, I think FS-1 matches up much better with any humbuckers like TZ, AN, etc...
jaxadam
03-19-2008, 05:22 PM
nullsys
I have been playing through the pickup selections and I think something IS wrong.
Heres an example, say volume wise, both humbuckers are at 10, the half-humbucker and half-single comes out at volume 2.
You can HARDLY hear anything when using both the single and humbuckers.
I think I have wired this wrong, can anyone give me any tips?
Also, the sound comes out gritty, digital sounding and just very bitey. This really isnt a normal sound at all.
nullsys
03-19-2008, 05:25 PM
nullsys
Just looking at this:
http://www.dimarzio.com//media/diagrams/B2.pdf
It looks different to how I have wired the middle pickup, BUT my selector switch doesnt look anytihng like that.
Mine only has a single row of pins on one side. Thats whats confusing me.
nullsys
03-19-2008, 05:28 PM
barbarelaxe
Posts: 906 - iTrader: (
That is because you have a standart 5 way switch. the one on the diagram is called multiport or something and you can buy one to replace your standart.
barbarelaxe
Visit barbarelaxe's homepage!
Find all posts by barbarelaxe
03-19-2008, 05:36 PM
nullsys
Why would I want to replace my standard one?
It worked with the S1 and V7 and V8, or are they tottally different?
nullsys
03-19-2008, 05:38 PM
barbarelaxe
If you wanna go for the wiring on the diagram you posted then you need to replace it.
barbarelaxe
03-19-2008, 09:25 PM
nullsys
Found out the GREEN and RED wires needed to be changed around.
Still fairly quiet but it works nicely in contrast.
Btw, can you hear a huge difference between the Blue Velvet and HS-2 ?
nullsys
03-19-2008, 09:54 PM
jaxadam
Classified Watchdog
nullsys
You can hear a huge difference between FS-1 and HS-2, and I believe FS-1 and BV are close in output.
jaxadam
03-20-2008, 06:24 AM
mscmkr
Posts: 19 - iTrader: (
nullsys
Try this
http://www.dimarzio.com//media/diagrams/C.pdf
mscmkr
Find all posts by mscmkr
03-21-2008, 12:05 AM
nullsys
According to DiMarzio:
Green goes where red should be on the position switch
Red goes to ground
Bare goes to ground
Black and White are connected to each other.
nullsys
03-25-2008, 03:20 PM
_FR0D0
Posts: 528 - iTrader: (
nullsys
Hi,
Tone Zone
, HS-2 and a Air Norton.
Now, the two humbuckers sound great, but when I switch into positions 2 and 4, which is supposed to have half bucker+single it sounds VERY tinny, looses its volume alot and makes a slight buzz sound when I pick hard on the high strings. It also looses its bottom end.
Can anyone help?
For the HS-2 you should try only using the red-black coil and keeping the green-white coil out of the circuit. You will get humcanceling in 2 and 4, but a true SC in 3, also your HS-2 will sould a lot more powerfull.
_FR0D0
Find all posts by _FR0D0
air norton
high strings
pickup selection
tone zone
is a middle pickup quiet?
how to quiet trem springs
how to keep guitar wireless unit quiet
my falsetto is quiet
how to make my amp quiet
Quiet Riot lead singer dead
moebius
Players, Bands, People, Music & Tours
05:50 PM
Firehouse, Quiet Riot, Ratt, Cinderella Tour
TAorama
Tours: Going to Shows
12:04 AM
Quiet Recordings
Kev Brigden
Recording Studio
12:38 AM
Building a Practice room - How to make it QUIET!!!!
oooo
Gear and Equipment
02:51 PM
10:35 AM
