Pickups & wiring
Ibanez/Dimarzio Pickup wire colours
Pickups & wiring
03-24-2003, 08:09 AM
Blues-core
Posts: 42 - iTrader: (
Hi, I'm just about to change the pickup in my rg565, open the cover and find that the colour codes don't match up with the standard Ibanez ones, This ibanez HB2 has black, yellow, red and blue wires.
I'm wanting to put in a dimarzio so what colour ibanez matches up with what colour dimarzio?
Blues-core
Find all posts by Blues-core
03-24-2003, 11:59 AM
cerealk
Posts: 2,428 - iTrader: (
wasnt there anything on the pages i refered to here in your other thread?
http://www.jemsite.com/phpbb/viewtopic.php?p=192377
cerealk
Visit cerealk's homepage!
Find all posts by cerealk
03-25-2003, 12:43 PM
Blues-core
That diagram doesn't really help, I could do with finding which wire is doing what on the ibanez pickup.
Blues-core
03-25-2003, 06:31 PM
Champagne Mist
Posts: 153 - iTrader: (
OK. i did this once. If you are going for a standard series connection, solder the dimarzio black and white wires together, the green and bare to ground, and the red to the guitar's hot output connection. Then when you are done, if the pickup is out of phase, just solder red to ground and green to hot. I'm guessing you just need to know what the existing connections are.
The ground should be easy to find--just some wires soldered to the back of a pot. Then the hot output would be attached somewhere to your
toggle switch
. Hope this helps
Jon
Champagne Mist
Find all posts by Champagne Mist
Champagne Mist
Oh, and unsolder all connections, rather than cutting them
Champagne Mist
03-26-2003, 01:50 PM
Blues-core
Thanks, I need to use my guitar tonight so I'll wait till tomorrow to try it.
Blues-core
07-07-2003, 09:28 PM
JEM10th
Posts: 231 - iTrader: (
Champagne Mist
The ground should be easy to find--just some wires soldered to the back of a pot. Then the hot output would be attached somewhere to your toggle switch. Hope this helps
Jon
How do I know if my PU´s are out of phase????
Pleeeeze!!!
JEM10th
Find all posts by JEM10th
07-08-2003, 12:28 AM
MicJustMic
Posts: 931 - iTrader: (
JEM10th
Champagne Mist
Jon
Pleeeeze!!!
Just listen to them, if they are thin, weak and nazal sounding, they are out of phase.
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
07-08-2003, 05:18 AM
JEM10th
I have wired up my JEM10th after "(Allparts model EP 0076-000) this is the best choice when installing a new 5-way, ......" - diagram.
Seems to me that the Evos has turned more to the treble side of the range. But if i follow the suggested diagrams, there should be no need for changing phase. The pickups shouldn´t differ or???
JEM10th
toggle switch
RG2610 one pickup?
ibanez 1570l discontinued?
what is a better pickup seymour duncan dimarzio
compare ibanez grx40 squier telecaster affinity
dimarzio pickup color swap?
05:13 AM
