Pickups & wiring
Ibanez RG320 > DiMarzios
Pickups & wiring
09-02-2006, 12:37 AM
bradc1988
Posts: 11 - iTrader: (
Ibanez RG320 > DiMarzios (Wiring)
Ok I put some DiMarzio's in my RG about a month back and I'm fairly certain the schematics I was following were wrong.
That's the one I was following, except I was told later to switch the red and black from the bridge, which I did.
Ok the way it sounds is this;
Bridge: Ugh...real trebly, thin and middy, souds really hollow
Middle: Nice clean, a lot more fuller than the bridge
Neck: Barely any volume at all, middle and bridge are much louder
The other 2 spots, 2 and 4, are also very low in volume.
So any help?
I only have some crappy
bass amp
to test any changes immediately, but I've been going to a
music store
to play it through an ENGL whenever I get the chance...the distortion sounds horrid the way these are wired.
12:56 AM
bradc1988
Find all posts by bradc1988
09-02-2006, 08:59 AM
toshiro
Posts: 1,812 - iTrader: (
Re: Ibanez RG320 > DiMarzios
Try swaping the red and black wires in that diagram.
Though, I would look for some RG7620 schematics, as that guitar used Dimarzio's stock and had the same switch postions.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
09-02-2006, 10:57 AM
Ozzdoc
Posts: 1,008 - iTrader: (
what Dimarzio's are they?
Ozzdoc
Find all posts by Ozzdoc
09-03-2006, 11:43 AM
bradc1988
Air Norton/D-Sonic
Not a Petrucci fanboy
Ok you mean for the bridge and the neck? I was told just to switch the ones from the bridge.
bradc1988
09-03-2006, 12:20 PM
toshiro
bradc1988
I mainly said that because that diagram shows the red being used as part of the series link, which is wrong for Dimarzios.
Here, give this a shot:
http://www.ibanez.com/wiring/wire.asp?y=2000&w=RG7620
(ignore that they list both as 'neck', the bottom pickup is the bridge)
toshiro
09-04-2006, 11:01 AM
bradc1988
That one is totally different to what I have now, I'll resolder that configuration tomorrow.
What wire do I need to connect the output jack to where ever it connects to? The wire was freyed, so I trimmed it, but now it's too short, so I need a new wire. So what wire do I need?
bradc1988
09-05-2006, 01:41 AM
toshiro
We used to chop up those cheap plastic-ended guitar cords for output jack wire. You want a shielded wire, 26 gauge or so stranded center conductor, using the outter shield wire as ground.
Something like the top one pictured here:
http://www.stewmac.com/shop/Electron...s.html#details
toshiro
09-05-2006, 06:13 AM
bradc1988
Ok, I'll get some tomorrow, thanks.
Soldering my pups now.
bradc1988
09-09-2006, 09:25 AM
toshiro
So, did it work?
toshiro
10-01-2006, 08:19 AM
bradc1988
Yeah my output jack is all good, no more scratching and buzzing.
Havn't had a chance to test my pups through a guitar amp yet, Uni is a real time drainer, but I'll hopefully make it into a store soon enough.
Thanks for your help so far everyone.
bradc1988
10-17-2006, 02:02 AM
bradc1988
OK!!! After many months of rewiring I think that it's finally done. I finally went to a store the other day and I was getting the expected tone, but there was this loud buzzing sound like there was no ground or something. But I think it was just me switching the wires to the output jack so I switched them and have to go in again to see if that buzz is still there.
Thanks guys, great help and it sounds like secks.
bradc1988
air norton
bass amp
music store
ibanez zps dont flutter?
compare ibanez grx40 squier telecaster affinity
where to get j.custom ibanez gakki
will an ibanez jem neck fit on an ibanez ex series body?
Ibanez & Vai timeline of events - working together
jemsite
Archived Topics and Common Questions - GO HERE FIRST
03:38 PM
'Custom' Ibanez
Shredder stuck in the 80s
05-16-2007
03:01 PM
Ibanez finally speaks about the fake Chinese models
NeglectedField
10:06 PM
Ibanez Counterfeit Warning!!!
Liggy
05:17 PM
Ibanez catalogs - call for scans
jemsite
82
03-27-2006
11:38 PM
03:36 PM
