Old 10-22-2006, 12:05 AM
isida.d  is offline
Posts: 299  -  iTrader: (0)
Important Pickup Ring Question
Ok, i have a strange question here.
I just finished installing a dimarzio d sonic into my ibanez RG570
i had my father do this because hes good with a soldering iron and i'm not, anyway i had to go out for a moment so i wasnt around when he put the pickup in the pickup ring and screwed it to the face of the guitar.
Originally the pickup rings were set up like so on the guitar:
on that angle with the neck facing the left the rings appear like this:
/ | / the middle line being the single coil.
Dad installed it like this:
My question is, the part of the pickup closest to the bridge will be lower than the part closest to the neck because of the way the pickup ring is now installed, does this make a big difference or much at all difference to the sound or is this negligable and the only reason why people install the rings / / is because of it looks more orderly.
Sorry for beating around the bush and i hope what i said made sense.
I know i can easily just turn the ring around but i was curious as to whether it made a difference.
Kind Regards,
Daniel
Old 10-22-2006, 04:57 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: Important Pickup Ring Question
G'day
If theres any differenc it would be minute.
Old 10-22-2006, 07:37 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
It doesn't matter except for appearance. It's just because of the way the springs are holding the pickups. You can often mess around a little with the screws, springs, and especially the pickup wires to change the way they sit.
pickup ring, pickup rings
Question about the pickup switch on my UV777P-BK Charlou Tech: Setup, Repairs and Mods 2 04-15-2006 11:40 PM
Pickup Question dragsternj Pickups & wiring 13 04-04-2005 12:13 AM
Pickup adjustment problem. RG-Head Tech: Setup, Repairs and Mods 2 01-29-2004 05:47 PM
Neck Pickup Question ???? wireman24 Pickups & wiring 5 03-14-2003 03:19 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
