Old 01-20-2010, 02:26 PM
dar88  is offline
Posts: 2  -  iTrader: (0)
Is there an internal difference between a Cor-tek 2502n and a cor-tek 5p toggle switc
Hi guys, my toggle switch Cor-Tek 5202N on my S series 520 died on me and i got a replacement cor-tek 5P switch! I've noticed that i had to wire it slightly different to get it to work but the bridge selector is sounding a bit different. Is there any major differences between the two switches internally?
Old 01-20-2010, 03:17 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
Re: Is there an internal difference between a Cor-tek 2502n and a cor-tek 5p toggle s
Yep, the 2505N is a special switch Ibanez uses in most HH guitars to get the stock pickup combinations. It is differently internally, I'm sure, but I couldn't say how. Regardless, you won't be able to get exactly the same combinations with a standard 5-way switch.
Old 01-06-2012, 09:51 PM
hotwax1989  is offline
Posts: 71  -  iTrader: (0)
@djohns74
I happen to come across a 2502N switch but dont know how to wire it, any more info on that switch? Can't find info on it anywhere.. thanks
Old 01-07-2012, 06:03 AM
xXLinkageXx  is offline
Posts: 379  -  iTrader: (0)
It operates very differently than the 5P, like this:
Use this diagram:
http://www.dimarzio.com/support/wiri...ms#1-1-2-19-11
Old 01-08-2012, 04:11 AM
Thanks, just what I was looking for!
cor-tek 5 way switch
3PS1SC5 2502N Switch Gone bad zepsongs Pickups & wiring 0 09-08-2009 05:18 PM
Internal Foil Shielded Cable. VBK-Shredder Tech: Setup, Repairs and Mods 0 08-14-2009 12:39 PM
3PS1SC5, SC-2502N 5 way switches (help with mods) 2TS Pickups & wiring 1 08-07-2008 11:01 AM
2502n DarthLamer Pickups & wiring 1 05-24-2008 05:50 AM
Js 3 way toggle vs. Lespaul toggle - can you get the same re SilverSurfer2 JS (Satriani Model) Ibanez Guitars 3 12-01-2001 09:27 AM
