Old 03-07-2007, 09:59 AM
snowjan  is offline
Posts: 14  -  iTrader: (0)
JEM BSB PROBLEM
I have a jem dbk that works perfect and I just got an old jem bsb with some problems the bridge pickup is really weak sounding and the tone seems to affect the bridge volume. Can any one say if the two should be wired the same ? so I can just copy the dbk or has anybody got any ideas ? ( I tried the dimarzio site but they don't seem to have the wiring for my selector switch or if they do its hard to make out)
Old 03-07-2007, 12:00 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Re: JEM BSB PROBLEM
definitely, different DiMarzios but identical wiring
Old 03-07-2007, 12:30 PM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
Re: JEM BSB PROBLEM
yep they SHOULD be the same but some one could have messed with it .
didn't the bsb have paf pros ? the paf pro imo is rather weak sounding in the bridge position , espcially compared to a breed which has a full and harmonically active sound .
Old 03-07-2007, 04:15 PM
snowjan  is offline
Re: JEM BSB PROBLEM
no the bsb has the full evo set
Old 03-07-2007, 04:23 PM
bammbamm  is offline
Re: JEM BSB PROBLEM
Try this:
http://www.ibanez.com/support/wiring/W96042.gif
The BSB came out in 96, and the diagram supports the BSB 777V and a number of other models.
Old 03-08-2007, 10:51 AM
snowjan  is offline
Thumbs up
Re: JEM BSB PROBLEM
thanks for the diagram thats the switch Ive got
Old 03-08-2007, 11:45 AM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
Re: JEM BSB PROBLEM
I read somewhere recently (I forget where), that if the tone pot significantly and adversely affects the volume of the pickup, that the pickup may have blown a coil. If you have a spare humbucker lying around, try throwing it in and see if the same thing happens- if so, the tone pot may be the culprit.
Old 03-08-2007, 02:41 PM
snowjan  is offline
Re: JEM BSB PROBLEM
well I did suspect the pickup had a bad coil so that does sound likely
Old 03-09-2007, 05:56 AM
nuno  is offline
Re: JEM BSB PROBLEM
Originally Posted by j.arledge View Post
yep they SHOULD be the same but some one could have messed with it.
that's what i meant.
Snowjan, open both the pickguards and see what's different. that's the only way to find the problem.
Old 03-09-2007, 02:04 PM
snowjan  is offline
Re: JEM BSB PROBLEM
I had a look inside them both and they are wired the same so that is making me lean towards the bad pickup idea
Old 03-11-2007, 07:18 PM
Steinway  is offline
Posts: 4  -  iTrader: (0)
Re: JEM BSB PROBLEM
Snowjan, can You draw DBK diagram pls? I have BSB and Breed on Neck have full sound, but Bridge EVO is strange...My Neck EVO had no bass response???
bass response, bridge pickup, bridge position, jem bsb, jem dbk, neck evo, paf pro, paf pros
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
WTB - Jem BSB... davenit Classified Ads: Ibanez JEM/UV Guitars 3 08-19-2005 10:49 AM
Someone responded to my WTB JEM 7 BSB ad. Now What? ginsu777 Vendors, Auction & Reseller Talk 12 03-02-2005 01:26 PM
Jem 7 BSB - Sniff and Yippie Jakan555WHT JEM and Universe Guitars 12 04-09-2002 06:35 AM
My first Jem! My first problem! - it was going so well... hamand JEM and Universe Guitars 9 02-17-2001 10:24 PM
