Originally Posted by Marcelo
I want to wire position mumber 3 as Jpm's 2(both hum. inner coils). Is it possible?
no, not with the stock switch, which is a strat-style 5-way. you've got 3 choices to get what you want:
first, a 3-way Tele blade switch. CrossingStar thoroughly explains how to wire that in his post above. however, with only 3 positions you will loose the in-between humbucker + middle single coil sounds.
second, you could use a Schaller Megaswitch Model E [see
www.stewmac.com ]. the wiring instructions for that special switch give the outer coils in position 3. but if you swap the hot and colored ground wires for both humbuckers, you'll get the inner coils instead.
this will give you in-between humbucker + middle single coil sounds, but they will be outer coil bridge HB + middle in position 4 and outer coil neck HB + middle in position 2. these sound fine, but many people prefer the stock JEM sound which combines the inner coils with the middle single. the inner + middle sounds are a little more chimey and less bright.
third, and the only way to get the exact JEM combinations with just position 3 changed to inner coils, is to use a 24-pole superswitch. dimarzio, all parts, and Fender all make different models that work the same way. you would need to draw up your own
wiring diagram.
so the easier options have more compromises, and the ones with fewer compromises are harder. just like life, i guess!
good luck with whatever you choose.
