Js1200 pickup configuration question
I was looking at the diagram on Ibanez's website for the pickup configuration on the Ibanez Js1200. I notice that on the neck pickup, the top single (the one closest to the neck) pickup is never engaged all by itself, only the bottom is when you pull up on the tone knob. Will it make a tonal difference if you can engage just the top one in the neck pickup versus the just the bottom one? Or will it pretty much yield the same tone??
I want to be able to get every single pickup configuration on my Js1200, i see some possible combinations that you can't get with the current switching (like the full neck pickup with a split bridge, full bridge pickup with split neck pickup, ...........
any thoughts as to how i can get all combinations out of these humbuckers??
Can you setup a blender to where you can blend the amount of mixed single coils/buckers between both pickups, or even between the two singles in one humbucker??
