Old 08-25-2009, 04:08 PM
ChopDuel  is offline
Posts: 27  -  iTrader: (0)
Question
killswitch and added noise/hum
Hey there
So I got a bunch of momentary switches, and decided to test one of them.
connected 2 wires to the switch (wrapped the copper around its legs through the holes and duct taped it tight) and connected them to the input jack from behind the guitar (no soldering or duct tape here, just inserted them till they held on)
now the killswitch did its job well, it killed the sound when pressed, but what i noticed is that there was a lot of extra hum when the guitar is idle, almost like the hum you get if you leave your wah pedal on. anyone knows what could cause this?
this is how i connected it:
http://alexplorer.net/guitar/mods/killswitch-after.jpg
update: the hum appears as soon as one of the wires touches the shorter leg of the input jack.
Old 08-25-2009, 04:33 PM
MarkE  is offline
Posts: 469  -  iTrader: (0)
Reviews: 15
Re: killswitch and added noise/hum
Installing the switch like that makes it work as if you unplugged your guitar, so nasty buzzing will be the result.
Old 08-25-2009, 05:28 PM
skins345669  is offline
Posts: 835  -  iTrader: (0)
You've wired it up right. Are you getting the extra hum when the killswitch is engaged, or disengaged?
Old 08-25-2009, 06:03 PM
ChopDuel  is offline
nice word play there
doesnt even matter, as soon as 1 wire touches the input jack non-ground leg, there's hum.
Old 08-25-2009, 08:07 PM
Glad you liked it
How many lugs does that switch have? I'm thinking of a way of wiring it up differently.
Old 08-25-2009, 10:29 PM
ChopDuel  is offline
it makes the same sound as it would make if i took the guitar cable out and touched its tip.
when i short both legs of the input jack there is silence, but if only the hot is touched (the tip of the jack inside the guitar) i get the hum
the switch has 2 legs
Old 08-26-2009, 09:22 AM
crossbones  is offline
Posts: 107  -  iTrader: (0)
I've had the very same problem. Not just with the killswitch. if when you touch something metal that isn't the strings then its the earths. In my case it was dry joints because the tip on my soldering iron was knackered. As its a heat controllable one I got it to work by turning up the heat and all my solder joints were dull not shiney!
Old 09-15-2009, 10:52 AM
ChopDuel  is offline
Problem solved, used this kind of wiring:
http://mystery.lastdrake.com/killswitch/3new.jpg
killswitch noise hum
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 09:00 AM
Killswitch in my RG 550 ?? IbanezFreak777 Pickups & wiring 10 08-04-2007 12:05 AM
Killswitch Aris_T Other Ibanez Guitars (including Premiums) 4 05-02-2007 04:30 PM
Killswitch? soothsayer Tech: Setup, Repairs and Mods 12 02-23-2007 10:26 AM
killswitch... HoP Pickups & wiring 0 08-15-2006 10:23 PM
