Old 05-12-2009, 10:06 PM
lateralus819  is offline
Posts: 102  -  iTrader: (0)
Reviews: 10
loop switcher help
so i got a problem, i ordered a loop switcher and im totally confused as to how to hook it up....heres how it runs...the return is connect to the output on my MXR 10 band EQ then that runs to my Boss DD-3 then the send runs into the input on the DD-3 thats the effects loop. the input on my amp runs down into my rocktron hush that runs into the out of my TS-9 that runs into the out of my SD-1 then the input of the SD-1 goes to my guitar...
The looper is a 2 loop pedal by loop master, it has a out, and an in on the sides and on the top is receive/send for loop 2 and the other side has receive/send for the loop 1, how do i hook all this up?i hooked it up fine with it all running to the input of the amp but it didnt sound the same so im clueless.
i wanna keep the dist/hush up front and the other 2 in the loop and use the looper to switch the sets off is this possible?
looper
FS: Axess GRX 4 midi controlled loop switcher chapelizod Classified Ads: Guitars and Gear 5 05-15-2009 11:45 AM
Loop switcher help lateralus819 Gear and Equipment 6 05-14-2009 09:46 AM
RJM RG-16 Loop Switcher reguv760 Gear and Equipment 1 03-14-2008 11:11 PM
WANTED: DMC Gound Control GCX Audio Loop Switcher sfx70 Classified Ads: Guitars and Gear 1 12-29-2006 11:37 PM
Loop switcher with midi Ving Gear and Equipment 3 02-16-2005 10:56 AM
