Pickups & wiring
Mid pickup suggestion for RG
Pickups & wiring
04-20-2003, 09:39 AM
SV300
Posts: 94 - iTrader: (
Im completely stuck here on choices for replacing the single on my RG.
Ive currently got a
Duncan Distortion
with an alnico V magnet (instead of the stock ceramic) in the bridge, and a Duncan Full Shred in the neck. The Distortion is fat and ballsy, and by comparison, teh Full Shred is quite tame.
For the mid pickup, i want a single sized humbucker thats something between the Distortion's ballsy fat sound and the Full Shreds tamer sound! Yes i know im asking for a lot! I know that single in teh mid position will give me more versatile tone, but the full shred wired in parrallel gives a real sweet tone which i absolutely love, and I hardly use singles in my playing anyway.
Please keep suggestions to Dimarzio and SDs, theyre the only ones i can get in Hong Kong. Ordering off hte net is not an option, my parents will slaughter me. SDs preferred, I get a discount from the dealer, hence they come out cheaper
but ill happily take a Dimarzio if they have one that fits my needs.
SV300
Find all posts by SV300
04-21-2003, 11:53 AM
frankfalbo
Posts: 1,875 - iTrader: (
Many of the duncan rails pickups should do, you might have to experiment. The Cool Rails , either neck or bridge, Hot Rails neck model only, and the lil 59 might all do the trick. Since you have already discovered the joy of parallel wiring, you could try that with the rails pickup in the middle. It could be just what you're looking for. My first recomendation would be the Cool Rails neck model, and my last choice would be the lil 59.
frankfalbo
Find all posts by frankfalbo
04-21-2003, 01:58 PM
Mandrak
Posts: 440 - iTrader: (
frankfalbo
I suggest you the DiMarzio Fast Track 1, after years (5 years) of research.
Mandrak
Find all posts by Mandrak
04-21-2003, 07:34 PM
frankfalbo
I 'm not sure why I was quoted, but the fast track is indeed a great pickup, and I have one in the middle and love it. Two main points in his post were that first, he'd like to stick with Duncans because he gets a discount on their products locally. Second, he admits to the versatility of a single coil in the middle, but doesn't want that sound. To me, the Fast Track is very good at reproducing a clean single coil tone. And it's output is lower than the Duncan products I listed. These are the reasons most of us, including me, like it very much, but he describes his ideal tone as one that's between his two current pickups. I thought the Cool Rails could do the trick.
frankfalbo
04-22-2003, 07:02 AM
SV300
Thanks guys.
Listening to the sound clips, I think I prefer the lil 59 tone a bit more though. INteresting, and it requires a lot of thinking. I asked over at the duncan forum, and got the same response, Cool rails of the lil 59.
SV300
04-30-2003, 01:12 PM
erikm5150
Posts: 195 - iTrader: (
Leandro and frankfalbo,
could you tell me how the fast track 1 sounds when split?
does it retain its characteristic single coil tone?
does it still have "decent" output to keep up with humbuckers?
i am also looking to put one in the middle position
it will be split in positions 2 & 4, and used in combination with the neck and bridge humbuckers (a
paf pro
and super dist.)
thanks
erikm5150
Find all posts by erikm5150
04-30-2003, 02:48 PM
frankfalbo
If you're going to split it in positions 2 and 4, then the only usable humbucking mode is 3, when its all by itself. And lots of people don't really use that position. So I would say just stick with a straight single coil, because the Fast Track is really thin, glassy, and low output when split. I do use it split, but I have a push/pull, so either both pickups are split to still cancel hum, or neither is split. If you're going to wire it to split with the humbuckers automatically, then a straight single coil wil sound better with stronger output than just one coil of the fast track. I guess I'm saying that I split my fast track out of necessity for hum-cancelling, not because it's some magical great tone that way.
frankfalbo
05-01-2003, 02:42 PM
Mandrak
erikm5150
...and used in combination with the neck and bridge humbuckers (a paf pro and super dist.)
thanks
Excellent combination ! Good luck
Mandrak
bridge hum
bridge humbucker
duncan distortion
paf pro
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
09:13 PM
