Old 04-23-2004, 01:28 PM
autospork  is offline
Posts: 5  -  iTrader: (0)
Middle position single coil recommendations
I have an H-S-S Kramer; the stock bridge pickup sounds pretty solid and I recently got an HS-3 in the neck.
Wondering what would make a good middle position pickup. HS2? Fast Track? Stick another HS-3 in the middle? A fridge magnet? The stock middle single-coil sounds decent clean, but lacking any definition whatsoever distorted. Soundwise, I guess I'm just looking for a typical middle-pickup Strat sound.
Old 05-18-2004, 12:02 AM
SliderJeff  is offline
Posts: 134  -  iTrader: (0)
Re: Middle position single coil recommendations
I think most of us around these parts either use the Blue Velvet or an HS-2. My S540 has an HS-2 as the middle coil and I have an HS-3 in my Fender HM Strat. Both get the job done, but it depends on the voltages of the surrounding pickups whether a given pickup will be overpowered or too overpowering in that position.
Later,
Jeff
Old 06-10-2004, 04:28 AM
nickcoumbe  is offline
Posts: 2,417  -  iTrader: (0)
Reviews: 34
I have a custom strat (HSS) with Paf pro/hs3/hs3. If you look at the Dimarzio page (as I am sure you have already) they suggest hs 3/2/1 from bridge to neck, or all hs3. I get really nice strat tones from mine clean, and OK distorted tones in the neck and middle.
I would go with the hs3. Although I have to say that I am thinking of putting something hotter in the neck position to try and give more of a HSH feel.
Old 06-10-2004, 03:45 PM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
I like the REd VElvet or the Virtual 2 bridge model in the middle.
~K
Old 06-10-2004, 11:45 PM
Mandrak  is offline
Posts: 440  -  iTrader: (0)
Why donīt you install your hs-3 in the middle position and buy a Fast Track I or a Chopper for the neck position?
The HS-3 in the neck position will sound too weak if you use one of the Velvets as your middle pickup.
Old 06-11-2004, 11:58 PM
Kontalonis  is offline
Posts: 1,006  -  iTrader: (3)
Andy timmons uses the Cruiser model. You might want to look into those.
Old 06-12-2004, 02:03 AM
carlos seo  is offline
Posts: 503  -  iTrader: (0)
Reviews: 5
For a Strat middle pickup sound, I recommend the Fender Texas Specials. They're really good!
Old 07-05-2004, 05:00 AM
superpato  is offline
Posts: 14  -  iTrader: (0)
i have an S470 (2001) and i am thinking of swapping the pups (AH series)
my question is this: according to the tone charts at dimarzio.com the velvets are very bright, how do they compare to the stock pup in my S470? that is a very bright pup and not in a good way, its kind of harsh and thin sounding i often find myself rolling the tone or volume knob down when using the middle pup.
I am thinking of getting one of these combos:
Evo bridge, HS-3 middle and humbucker from hell
Super distortion bridge, HS-3 middle and humbucker from hell
Evo bridge, HS-2 middle and Evo neck
i play in a cover band and i need good distorted sounds and clean clear sounds in one guitar
i run my guitar into a POD xt and a open back 2x12
Old 07-05-2004, 08:13 PM
7 Dying Trees  is offline
Posts: 1,708  -  iTrader: (4)
Blue Velvet, sounds ace, nuff said
Old 07-08-2004, 10:56 PM
EnigmaUV7  is offline
Posts: 206  -  iTrader: (0)
Get the Dimarzio HS-3 or YJM, they have true single coil tone and noise cancelling. I hate blade type humbucking single coils, they defeat the purpose of a single coil tonewise and have too much bass/midrange.
andy timmons, bridge pickup, distorted tone, distorted tones, evo bridge, neck position, paf pro, strat sound, strat tone, super distortion
