Old 04-23-2009, 03:55 PM
andyt  is offline
Posts: 347  -  iTrader: (0)
middle single not working
Wiring help please, wired up my jem build following dimarzio instructions, its all the same but my 5 way switch is a 8 in line one, not the 4 per side like their pic. Single coil doesnt work on its own, but does in positions 2 & 4 giving straty sound.
thanks
Old 04-23-2009, 04:52 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: middle single not working
andy, on an 8 inline switch the mid pup should be the soldered to the second lug from the end. connections are as follows
depending on which side you view, one will be - left to right:
1. not used
2. bridge coil split
3. neck coil split
4. ground
5. output
6. bridge hot
7. mid hot
8. neck hot
Old 04-23-2009, 05:27 PM
andyt  is offline
1. not used
3. neck coil split
4. ground
5. output
6. bridge hot
7. mid hot
8. neck hot
Wow I'm completly wrong, I've been using this
& have added in the text to relate to the dimarzio diagram
which translates to this?
1 bridge hot
2 middle hot
3 neck hot
4 output - the one connected to the volume pot?
5 not used
6 bridge split
7 ground
8 neck split
Old 04-23-2009, 06:30 PM
Jaden  is offline
sorry mate I was talking crap...
the one you have there is correct.
Old 04-23-2009, 06:39 PM
andyt  is offline
no prob J, but still begs the question why the middle isn't working?
Old 04-23-2009, 06:54 PM
Jaden  is offline
have you done all the usual tapping the pole piece testing ?
I cant think why it would work in those 2 positions and not alone !
Old 04-23-2009, 06:58 PM
andyt  is offline
could it be the switch not connecting in position 3?
Old 04-24-2009, 05:09 AM
Jaden  is offline
yes, those import type switches sometimes the lugs are crap, if you move them around you can get a connection.
Old 04-24-2009, 06:45 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
It's worth doing the tap test as you may be hearing coil tapped humbuckers on their own in position 2 and 4 which will sound "stratty" check that the single coil is active in pos 2 and 4, if not then the pickup might be dead. If it's definitely working in pos 2 and 4 then the switch may be duff. Don't forget the only connections to the single coil are to the switch - lug 3 on your diagram and to the earth - volume pot casing.
Jim
Old 04-24-2009, 10:05 AM
andyt  is offline
Jim
cheers guys, tap test - single works in 2 & 4 so must be the switch
pickup installation
Which middle single to pair with mo'joe and paf joe j.arledge Pickups & wiring 1 12-13-2008 04:52 AM
Best middle single coil in HSH P/up configuration? Smitty Gear and Equipment 5 08-14-2007 06:30 PM
Middle single coil Jeff - CRO Pickups & wiring 24 12-02-2006 03:33 PM
Reverse polarity middle single coil? allanw Pickups & wiring 6 01-15-2006 11:14 PM
Can't get single coil in UV working... grrrrr ecalcagnino Pickups & wiring 5 04-25-2005 02:59 PM
