Old 03-24-2006, 07:13 AM
bujecas  is offline
Posts: 24  -  iTrader: (0)
More warm pickups to a Ibanez RG550
Hello,
My Ibanez RG550 have V7(neck), S2(middle) and V8(bridge) pickups. The pickups have good attack and presence but sometimes they are a little sharp. I want a more fat, warm tone, maybe more close to the Steve Vai tone.
My question is: What pickups do you recommend? DiMarzio, Seymour Duncan, others? Which models?
Thanks.
Old 03-24-2006, 08:01 AM
bikeman  is offline
Posts: 660  -  iTrader: (5)
Re: More warm pickups to a Ibanez RG550
If you want the Vai tone, get Vai pickups!
Old 03-24-2006, 09:33 AM
frankfalbo  is offline
The Breed set is probably perfect for what you're describing. You could leave the S2 middle pickup if you wanted to. I have a 570 with a Breed neck and S2 middle, and they work well together.
Old 03-24-2006, 10:02 AM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
PAF Pro
Old 03-24-2006, 11:40 AM
erikm5150  is offline
Posts: 195  -  iTrader: (3)
Breed for the bridge.
They were designed to give a fat warm tone on tremolo superstrats.
and vai uses them too.
PAF Pro for the neck, or Breed neck.. they are pretty similar and both will work well with the breed bridge.
Old 03-24-2006, 11:27 PM
phantoms  is offline
Posts: 304  -  iTrader: (2)
What is the sound difference between a S2 and S1 mid?
Old 03-25-2006, 03:44 AM
TongueShredder  is offline
Posts: 1,705  -  iTrader: (0)
DiMarzio Paf Pro(both bridge and neck) or another option is Seymour Duncan JB(Bridge), Hot Rail(Middle), 59(Neck).
Old 03-25-2006, 04:13 AM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
For the kind of tone you're talking about, I would say that the Breed is what you want in the bridge. As for the neck, if you're after that Vai tone then I would probably go with either the Breed neck model or a PAF something or other (Pro, Joe, Classic, they're all good choices).
Old 03-25-2006, 04:52 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Originally Posted by kennydoe
PAF Pro
+1 Paf pro is nice and warm
Old 03-25-2006, 02:10 PM
red5  is offline
Posts: 2,639  -  iTrader: (0)
PAF Pro
That's my 2 cents too. Can't go wrong with PAF Pros or Breeds really...
Old 03-26-2006, 03:50 AM
kennydoe  is offline
I've had PAF Pros and Breeds in similar guitars and preferred the PAFs exponentially over the Breeds.
~K
Old 03-26-2006, 07:13 PM
bujecas  is offline
~K
What's the real difference you noted between them?
Old 03-26-2006, 10:39 PM
kennydoe  is offline
PAF had a better presence, harmonically. i felt the Breed was really missing something.
~K
Old 03-27-2006, 02:37 AM
marlb5150  is offline
Posts: 158  -  iTrader: (0)
super distortion- bridge - sounds warm and fat, with slightly cutting treble (controllable with the tone knob).
PAf pro - neck
Old 03-27-2006, 06:01 AM
bujecas  is offline
I was mistaken, my middle pickup is an S1. It's also compatible?
F/S: Ibanez 1991 RG550 in Laser Blue gpenguins Classified Ads: Guitars and Gear 2 04-22-2005 12:38 PM
A/B test between Ibanez RG7421 and Schecter 007 Blackjack Mind Riot Other 7-string Guitars 23 12-06-2004 02:12 PM
