Re: Neck Evolution pickup sounds weak and tinny
Pretty sure that reversing the pickup is a red herring for this problem as it only determines which coil is dropped in the neck/middle position.
If it sounds thin, check that both coils are hot (with the switch in the neck position) by tapping the polepieces with an Allen key.
If one coil is off/quieter, check your wiring to make sure nothing's grounded where it shouldn't be and that your hot connections are strong.
If both coils are on and have similar output, check that the pickup hasn't been wired out of phase.
