Pickups & wiring
Need help installing Dimarzio in RG570!!
Pickups & wiring
04-18-2006, 08:40 PM
King Nothing
Posts: 333 - iTrader: (
I'm replacing the v8
bridge pickup
in my guitar with an Evo and am confused about how to do it. The stock pickup has a bare ground wire, a red wire, and a white wire. The dimarzio has bare, red, white, green, and black. Where do I connect the extra wires?
I'm guessing red goes to where the old red was, white goes where the old white was, green and bare both go to ground, so that leaves black
Thanks
-Chris
09:06 PM
King Nothing
Find all posts by King Nothing
04-18-2006, 09:29 PM
toneboy
Posts: 1,665 - iTrader: (
Re: Need help installing Dimarzio in RG570!!
From the Dimarzio website:
For normal series-humbucking wiring, solder the black and white wires to each other and insulate that connection with tape. The red wire is the hot output and the green and bare wires go to ground, usually by soldering them to the back of a pot. If the pickup sounds "out-of-phase" when played with other pickups, use the green as hot and connect the red and bare to ground.
For further instructions select the PICKUP button at the top of the page. Select the model you are interested in. Then select the WIRING DIAGRAMS button.
Now look at the
wiring diagram
posted on this website:
11:46 PM
toneboy
Find all posts by toneboy
04-18-2006, 09:33 PM
King Nothing
The link doesn't work!
The info you quoted from their site is for series humbucking though, I need to know what to do for coil tapping/splitting. I want it to work the same as the stocker did
King Nothing
04-18-2006, 09:58 PM
King Nothing
So unless someone tells me differently, I'm gonna solder the red where the old red was, the white where the old white was, the green and bare to ground, and solder the black to the same place as the white.
Please let me know if this is wrong guys!
King Nothing
04-18-2006, 11:36 PM
King Nothing
well I did what I wrote above. I jsut gotta reattach the bridge and retune and I can try her out and see if I wired it right.
King Nothing
04-18-2006, 11:48 PM
toneboy
King Nothing
Sorry about that but then again, I found it here. Did you try looking for the info here in the Setup section? I just knew where it was because I figured it would be here, considering all the information that's available here.
Yes, I am aware of that. The information I provided from Dimarzio's site was intended to inform you of the pickup's wiring arrangement.
toneboy
04-19-2006, 12:00 AM
King Nothing
sweet, well it looks like i did it just like the pic for the jem except i put the green and the bare on the bottom of the volume pot. I'll find out in about 5 minutes if it was right
King Nothing
04-19-2006, 03:18 AM
Wolfram
Posts: 911 - iTrader: (
Reviews: 12
Hey I am having the same problem. I have an RG520 and want to replace the V8/V7 pickups with a FRED in the bridge and a
PAF PRO
in the Neck. How did it work for you KING Nothing?
HELP
Rgds Wolfram
Wolfram
Find all posts by Wolfram
04-19-2006, 12:22 PM
King Nothing
it worked perfectly.
I didn't realize the Evo would be so crunchy
King Nothing
04-20-2006, 08:45 PM
ScottB
Posts: 2,208 - iTrader: (
Evos work very well with medium gain, classic hard rock sounds. Crank the volume as loud as your neighbors can stand it and keep the gain no higher than it takes for the amp to break up and sizzle a bit.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
bridge pickup
coil tap
coil tapping
paf pro
wiring diagram
how to put a chrome cover on my dimarzio pickup?
which way do dimarzio go in
what's hotter EMG 81 or Dimarzio X2N
which dimarzio most like duncan jb
dimarzio ibz?
2002 rg570 vs. 2003 rg350dx
avicenna77
01:50 AM
FS: Brand New In box Dimarzio pickups.
megadeth
10:03 PM
...in praise of DiMarzio
ibanez otaku
Gear and Equipment
08:07 PM
Parker Fly owners, pickup info.
bammbamm
Pickups & wiring
10:35 AM
04:26 AM
