Old 06-06-2009, 02:03 PM
nicolasroy  is offline
Posts: 8  -  iTrader: (0)
Unhappy
Need help installing new pickups!
Hi, I am in trouble.
I have an Ibanez RG Prestige 2550EGK with DiMarzio/IBZ pickups.
I just bought an AirNorton and a DSonic to replace the 2 original H but I want to keep the IBZ middle S since I don't use it too much.
So I soldered the 2 new H wires exactly where the originals were soldered.
But now I have an incredible hum!!
I am pretty sure all my solderings are good, I am testing the grounds with a multi-meters and everything seems good but the hum is really bad.
Any ideas? Maybe I have to inverse the 2 wires of the single to match the two new Humbeckers?
Another info: when I touch any components of the electronic section, pickups, pots, bridge etc...I hear a pop and the hum behaviour seems to change.
Please help!!
Old 06-06-2009, 02:50 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
Re: Need help installing new pickups!
are you sure they're wired properly? Not quite sure if DiMarzio/IBZ's use the same color codes as straight Dimarzio's but they're usually wired like this:
green + bare = volume pot (ground)
black + white = switch (coil tap for pos 2 + 4)
red = switch (hot)
don't need to reverse wires for the single coil.
Reg
Old 06-06-2009, 02:59 PM
green + red = volume pot (ground)
red = switch (hot)
Reg
You mean green + bare = pot? This is what I did...
Black + White togheter on the same place where the IBZ were...
Red = to the same place where the IBZ were...
But the hum is unbarable...
I don't know what to do :-(
Old 06-06-2009, 03:42 PM
reguv760  is offline
Images: 5
Reviews: 12
mmm... double check if all the grounds are connected; from the pots, jack and to the claw. Sounds like a loose ground wire somewhere in the circuit.
Reg
Old 06-06-2009, 04:57 PM
Reg
They all seem ok...but what do you mean the the claw?
Old 06-06-2009, 05:05 PM
reguv760  is offline
Images: 5
Reviews: 12
the spring claw
Reg
Old 06-06-2009, 05:19 PM
the spring claw
Reg
Which is connected to the bridge, yes all ground are connected together, and connected to the ground of the input jack.
hum, installation, noise
Installing EMG active pickups LonePhantom Tech: Setup, Repairs and Mods 16 02-17-2010 12:22 PM
Installing Dimarzio PickUps XcitR Pickups & wiring 3 05-26-2008 11:21 AM
Installing Pickups in a Jem FP Aaron_Jem_FP Tech: Setup, Repairs and Mods 6 07-05-2007 12:34 AM
(re)installing pickups on a Jem5 Thared33 Pickups & wiring 0 06-14-2007 06:08 AM
Installing Evos - How do I wire up these pickups??? Cypher Tech: Setup, Repairs and Mods 3 07-21-2001 10:42 PM
