Old 06-07-2008, 05:26 PM
TroelsRasmussen  is offline
Posts: 35  -  iTrader: (0)
Need help to wiring a RG 1527
I know you have seen a post like this a thousand times before, but I really do need your help.
I have just bought a DiMarzio D-Sonic 7 and a Dimarzio Air Norton 7. I tried to wire them today but my wiring does not work. I wired them using this diagram: http://www.tremol-no.com/images/DiM_8poleRev2.jpg
However, it does not work - maybe I have made some mistakes. Any help please?? To diagrams etc...
Thanks!
Old 06-10-2008, 11:27 AM
tony777  is offline
Posts: 296  -  iTrader: (3)
Re: Need help to wiring a RG 1527
The wiring diagram on your link is correct, so you must have made some mistake.
You need the stock pickup switcher.
and be sure all grounds and hot wires are soldered correct.
Tony
Old 07-19-2008, 02:29 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
The switch in the diagram you show is NOT the same switch as the 1527. 3 pickup guitars use a switch that looks the same but does not operate the same as the switch for a 2 pickup Ibanez. I found this out after soldering for 2 hours only to discover the switches are different. If you want to use 2 pickups only without a middle pickup, I have the proper switch for that so email me.
Old 07-20-2008, 09:09 AM
horstausmforst  is offline
Posts: 663  -  iTrader: (1)
iirc, the 1527 has 2 pickups. he should have the right switch already.
Troels, what exactly does "not work"? No sound at all, noise, buzzing, etc. ..?
dimarzio air, pickup switch
Need Help with Wiring diagram for RG 340 roadstar stratosqueeg Other Ibanez Guitars (including Premiums) 1 04-05-2006 11:24 PM
Rg 2020x wiring help , dimarzios LennyX Other Ibanez Guitars (including Premiums) 1 04-30-2004 02:46 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
RG 620X Wiring Problem kirk Tech: Setup, Repairs and Mods 43 08-23-2002 05:51 PM
