I want to wire my RG for two humbuckers DP151 (
PAF Pro) bridge and DP156 (Humbucker From Hell) Neck.
I have a 5 way switch with 8 connections, 1 volume, 1 tone
I want my switch to have the following options:
Bridge Humbucker
Bridge Single Coil
Bridge&Neck Single Coil
Neck Single Coil
Neck Humbucker
Now, i understand that there is something called parallel and series and
that the humbucker can act as a single coil but not tapped...
I don't understand all of this mess, i just want Humbucker option as Humbucker and single coil as true single coil (splitted humbucker).
This is the closest i found from the stickies:
http://www.seymourduncan.com/support...ic=2h_1v__5wss
The problem is that my 5 way switch has only 8 connections and
that there is no tone knob in the diagram and also i don't know if
in this diagram single coil means true single coil and if humbucker is
what it should be (i don't understand that parallel series thing).
Long story short, i need help.
Happy Rockin' New Year!
Roi.
