I'm wondering if anyone can help me.
I want to wire my Ibanez RG4EX1 so that it has the same
pickup selection as the Ibanez SV5470:
http://www.ibanez.com/support/wiring/2008/SV5470.pdf
I bought the following:
Bridge pickup - Dimarzio D activator X
Middle Pickup - Dimarzio Fast track 1
Neck pickup - Dimarzio D activator X
5-Way Super switch
http://www.stewmac.com/shop/Electron...s.html#details)
500K Push/Pull volume switch
Obviously NOT the same configuration as in the Ibanez SV5470 diagram.
My Push/Pull switch is a standard, whereas the Ibanez is a 12 pin push/pull.
I'm also not sure if the Ibanez VLX91 5-way switch has the same pin out as the Super Switch that I have.
Is there any way to achieve the SV5470 wiring combination with the Config that I have?
