Old 08-07-2008, 03:57 PM
martyman  is offline
Posts: 2  -  iTrader: (0)
Question
Need help with JEM wiring plus Bridge HB and Neck HB combination
I am wiring up an old Jackson Dinky Professional with SD Invader in bridge, DiM HS-2 in middle and Screamin' Demon in neck. I have a DiM EP 1112 5 position multi-pole switch and some push-pull pots. I am thinking of doing the standard JEM wiring from the diagram on the Ibanez website, with two modifications: (1) I think I can tap the HS-2 with a push pull pot and (2) I'd like to get the option to use the bridge and neck HB combination by using a push-pull or a toggle to have an "always on" for the bridge HB.
I can't figure out if the coil tap and the always on go before or after the multipole switch. If anyone knows and can sketch this out, I'd be much obliged.
Thanks,
Marty
dimarzio ep 1112, jackson dinky, pole switch, standard jem, wiring, wiring diagram
Evolution Neck as a Bridge w/ PAF Pro Neck t1r12003 Pickups & wiring 6 12-03-2007 07:38 PM
hard choise: Blaze Neck in bridge vs. Blaze Bridge in bridge... MF_Kitten Pickups & wiring 13 04-23-2007 11:33 AM
Help choosing a Bridge humbucker/Neck single-coil combination syan Pickups & wiring 0 11-29-2006 11:42 PM
Breed neck / bridge difference in bridge position marino Pickups & wiring 2 05-25-2005 09:43 PM
evolution bridge + paf pro neck - > good combination? Pee Pickups & wiring 2 04-10-2003 09:52 AM
