Old 11-09-2008, 09:07 PM
Silver Sable  is offline
Posts: 130  -  iTrader: (0)
Need wiring help for 7420 modified
I have taken a 7420 and routed out a single coil middle pickup. I've refinished and everything and now I'm down to rewiring. I've tried using the diagrams for the original universe, but that has created something all messed up. Any help would be much appreciated.
Neck - Air Norton 7
Middle - Blaze 7 single coil
Bridge - D-Sonic 7 with the rail on top
I left the original 5 way switch that came with it. PLEASE help, I'm so confused.
Old 11-09-2008, 11:28 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
Re: Need wiring help for 7420 modified
The stock 5-way switch on a 7420 is specially designed for two humbucker guitars. It might look similar, but the various lugs aren't wired the same way as a standard switch. I'm not sure that Ibanez ever used that switch on an HSH guitar, so I don't know if there's much in the way of wiring diagrams out there for that configuration, or if it can even work correctly. I hate to make recommendations based on a lack of knowledge, but I'm thinking you ought to just pick up a standard 5-way switch and use that instead.
Old 11-10-2008, 12:43 AM
jazzedout  is offline
Posts: 671  -  iTrader: (5)
Yeap.... get a new 5 way switch for a 3 pickup guitar. The one you have won't do...
Old 11-10-2008, 03:48 PM
Well, I got it wired up and it does have a lot of versatility already. It just sounds like it blends the middle pickup with the others in the middle three positions. But it sounds pretty awesome already. Kinda like it is running itself in chorus already... awesome, but a bit strange.
I'll search around at home to see if I have another switch... I think I should have one that came off an RG550... I'll have to see if they are the same size or not... Maybe that'll work. I'll see if it really makes a difference and which one sounds more interesting overall.
Thanks gents!
Old 11-10-2008, 05:02 PM
The one from the 550 should do just fine...
Old 11-11-2008, 12:18 PM
Actually the one that came in it works great. I don't know how or why, but it works. I'm happy now!
Thanks all!
wiring 7420/universe
Modified strats shredfreak Other 6-string Guitars (non-Ibanez brand) 10 09-25-2005 05:45 PM
modified S-270 straymond Other Ibanez Guitars (including Premiums) 4 09-07-2005 01:34 PM
modified js100 what else to do? the_roadrunner JS (Satriani Model) Ibanez Guitars 13 12-02-2003 10:22 AM
Modified PGM30WH Scott 74 Tech: Setup, Repairs and Mods 1 09-22-2003 01:17 PM
Anyone modified as JS? - Is so, what have you done? satch JS (Satriani Model) Ibanez Guitars 8 01-14-2002 03:43 PM
