Old 08-24-2007, 12:29 AM
morajosyvy  is offline
Posts: 46  -  iTrader: (0)
Noise in Tone Zone
I have air norton on neck and tone zone in bridge, is it normal that the tone zone is more sensible to electromagnetic fields like a tv screen than de air norton?
Old 08-24-2007, 12:58 AM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
Re: Noise in Tone Zone
No, it's not. If the coils have an equal number of turns, the hum cancelling should be pretty close to 100%. Certainly shouldn't introduce any more noise than the Norton in any case.
Old 08-24-2007, 10:51 PM
That's weird because my RG3120 makes de same hum noise with the tone zone pickup enabled
Old 08-24-2007, 10:53 PM
Actually when there are no EM fields near neither of the pickups make noise , but in front of a Tv screen in both guitars the tone zone makes more noise.
Old 08-25-2007, 10:06 PM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
my tone zone also makes as much noise as a single coil, no tv or lights on.
Old 06-11-2008, 07:44 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
I'm resurrecting this thread because I ran across it searching for something else and I have something to add.
Dimarzio uses a method for making some of their pickups called Dual Resonance. This means that some of their humbuckers have 2 coils that are not wound exactly the same. The net results is they can get some pretty cool tones from their pickups and their pickups are more susceptible to noise.
I've got Tone Zones in a few guitars and they are much noisier than a guitar I have with a Duncan or even my Brian May guitar with its single coils in humbucking mode.
Old 06-11-2008, 10:11 AM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Well... I don't think that is the case regarding the TZ. AFAIK, the TZ is symetrical (both coils are equal).
Old 06-11-2008, 11:05 AM
toneboy  is offline
Check Dimarzio's website. The description of the Tone Zone specifically states that it has dual resonance coils. I've been using the Tone Zone since it first came out in '91 so if there's one pickup I know intimately, it is the Tone Zone.
Old 06-11-2008, 11:34 AM
toneboy  is offline
BTW, for further confirmation go to the U.S. Patent Office's website and do a search for patent#4501185. That's the patent for Dual Resonance technology and that patent number is listed in the Tone Zone's description on Dimarzio's website. Quite a few Dimarzio pickups use that technology.
How it works is each coil uses a different gauge of wire but approximately the same number of turns. This results in each coil having a different inductance/output which in turn changes the tone of the pickup. Pretty ingenious.
Old 06-11-2008, 01:04 PM
Reviews: 4
Talking
Sorry... my bad.
Old 06-14-2008, 03:09 AM
rub_800  is offline
Posts: 93  -  iTrader: (0)
I think that the humbuckers eliminates the hum because the two coils, one coil against the other eliminates the hum.
But if the coils are different they won't have the same "amount of hum" so one of the coils "wins" and some hum scapes.. This tricky :s, I don't know how to explain it..
Old 06-14-2008, 10:23 AM
SAVAGEDISTORTION  is offline
Posts: 72  -  iTrader: (0)
if you want a tone zone wthout any noise try the duncan blackout bridge pup
it has a tone zone like sound(real warm,fat, megadriving and wicked harmonics but absolutely NO NOISE
Old 06-14-2008, 02:24 PM
mozfan98  is offline
Posts: 62  -  iTrader: (0)
I think those 2 pickups sound completely different. I don't find the blackouts fat sounding at all unless you're using the neck pickup as a bridge. If you're comparing an active to a passive Tone Zone, I'd say an EMG 85 is the closest sounding to a Tone Zone.
Anyways, I find the following pickups that have the hum..Tone Zone, Breeds Set, PAF Pro, EJ Custom. Coincidently they all have the A 5 Magnets, which I thought had a correlation to the hum. The ones that I find are very quiet are the Steve's Special and the Evolution, coincidently both use ceramic magnets.
Old 06-14-2008, 03:48 PM
it is true that the cerammics produce less noise
as far as the blackout bridge mine is fat as all hell
it is in a mahogany RG(3120)
Old 06-15-2008, 01:59 PM
mozfan98  is offline
Interesting, I had blackouts in my all mahogany Jackson COB model and a mahogany BC Rich V and it sounded crunchy without the fatness to it. Reminds me a lot of the EMG 81. Different guitars despite the same species wood sound different.
air norton, dimarzio pickup, tone zone
TRADE: My Black Tone Zone for White t1r12003 Classified Ads: Guitars and Gear 1 07-26-2007 01:39 PM
Tone Zone 7 a good choice? Labrie Pickups & wiring 6 05-18-2005 12:25 AM
WTT: My non f-spaced Tone Zone for a Tele Tone Zone the second eye Classified Ads: Guitars and Gear 0 05-03-2005 01:24 AM
Pickup help, Tone Zone in bridge. matt_cater Pickups & wiring 2 08-08-2004 01:56 PM
the dimarzio tone zone! for those that find it mushy,muddy VOLTAGE Pickups & wiring 8 10-20-2003 12:40 AM
