Old 06-25-2005, 05:03 PM
7-request  is offline
Posts: 18  -  iTrader: (0)
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only)
hmm, newbe here,...
i just wondering and need pure singe coil sound on my rg 1527... (stock, nothing change yet)
i would like to do switching in this way,..
position 1 = Neck (Hum-series)
pos 2 = Neck (Single coil mode)
pos 3 = Both hum
pos 4 = Brigde (Single Coil mode)
pos 5 = Brigde (Hum-Series)
is it possible without adding coil tapper or adding other parts???...
just using stock pups and switch, how the wiring diagram will go???
thanks...
Old 07-05-2005, 02:15 AM
rory  is offline
Posts: 102  -  iTrader: (0)
Re: ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only)
The stock switch is custom-designed and will only give you one combination of sounds. I ran into the same problem when I pulled the mid-position single coil from a 570 and wanted switching similar to my 7620. I'm sure you could get that combination using a 4-pole 'superswitch' but I couldn't begin to tell you how to do it...maybe someone who knows a bit more can shed some light.
Old 07-05-2005, 12:18 PM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
That's a new one to me. I'd ask the people over at Dimarzio how to do it. They're really quick with things like this and they'll even send you the diagram of how to do it as well as info on any other parts that you might need to accomplish it. But know this: no humbucker will sound like a true single coil in split mode, and the crappier the humbucker the crappier the impersonation.
coil mode, coil tap, wiring diagram
how many Ibanez guitars do you own? spacenuke Other Ibanez Guitars (including Premiums) 1534 01-22-2012 05:08 PM
IBANEZ S470/EMG pickups/VLX91 switch and a stereo jackplug!! spacecadet2004 Other Ibanez Guitars (including Premiums) 0 04-19-2004 02:34 PM
s1 switch & ibanez s coil tap Screaming Wind Tech: Setup, Repairs and Mods 1 03-08-2004 11:14 PM
Fat Strat with coil split switch? cypher2198 Pickups & wiring 1 05-30-2003 11:50 AM
Ibanez J-Custom & Prestige Overview and F.A.Q. jemsite J-Custom, USA Custom & Prestige Ibanez Guitars 0 05-16-2002 01:48 AM
