Pickups & wiring
Ok pickup gurus: how do I get middle split setting here?
Pickups & wiring
06-27-2009, 08:49 PM
Petie
Posts: 2,878 - iTrader: (
I'm going to get me a set of the new
DiMarzio
John
Petrucci
pickups, and I would like to wire it like this:
1 Bridge humbucker
2 Bridge coil tap
3 Neck + bridge coil tap
4 Neck coil tap
5 Neck humbucker
The closest I can find is this wiring, which is the same as above but position 3 is the neck + bridge humbuckers.
http://www.guitarelectronics.com/product/WDUHH5L1101
So what would I need to do in order to get the switching I want?
Petie
Visit Petie's homepage!
Find all posts by Petie
06-27-2009, 10:04 PM
littlephil
Posts: 422 - iTrader: (
Re: Ok pickup gurus: how do I get middle split setting here?
I think you would need a superswitch like the VLX91.
That or you could go a 3 way switch with a push/pull for the coil tap, that would be the cheapest way, plus you get the option of both full humbuckers.
littlephil
Find all posts by littlephil
06-27-2009, 10:33 PM
toneboy
Posts: 1,665 - iTrader: (
Contact Dimarzio via e-mail. If it can be done, they know how.
toneboy
Find all posts by toneboy
06-28-2009, 08:32 PM
Petie
littlephil
I thought about the 3-way + coil tap push/pull option, but I really dislike the sound of two humbuckers running at once (at least, when I can't adjust the volume of each pickup like on a Les Paul). Plus I'd prefer to be able to go instantly from bridge humbucker to bridge/neck single coil mode, and it's a little too finicky to flip the pickup switch AND pop up the volume control at the same time.
I'll email Steve at DiMarzio and see if he can help me. If all this fails I have a complete wiring harness from an RG1527 waiting to be dropped into a guitar, even though there are 2 settings on it which I'd probably never use.
Petie
06-28-2009, 11:25 PM
littlephil
Other than the VLX91, if you dont really need positions 2+4 with the individual humbuckers split, you could get a 4PDT 3 way like Petrucci uses to get the split humbuckers in the middle position, but you'd loose the neck split and bridge split selections.
littlephil
06-29-2009, 12:06 AM
Petie
I thought about that but none of these positions are an afterthought, they're all exactly what I want, in the order I want them.
Petie
06-29-2009, 04:30 PM
Vim Fuego
Posts: 908 - iTrader: (
Here you go...
Jim
Vim Fuego
Visit Vim Fuego's homepage!
Find all posts by Vim Fuego
06-29-2009, 08:42 PM
Petie
Wow, thanks so much!!! Time to order me a VLX91.
Petie
dimarzio
petrucci
pickup wiring
RG2610 one pickup?
how to do a herman li coil split
when to use middle pickup
Evo 2 is the best pickup of all
how to get a korn setting
Middle Pickup Advice!~
michaelap
Pickups & wiring
12:06 PM
Middle pickup. Do I really need RW/RP?
rdm
Pickups & wiring
08:14 AM
Changing middle position setting on SZ series.
Rotti
Pickups & wiring
10:38 AM
Need Middle Pickup Cover
atpspc
05:59 PM
12:43 PM
