Old 09-16-2005, 11:27 PM
Thrash  is offline
Posts: 679  -  iTrader: (2)
Passion and Warfare
Was Steve using Paf Pros at this time ?
Old 09-16-2005, 11:38 PM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
Re: Passion and Warfare
it was either paf pros or the blaze set . I think those where the only two pickups he was using.
i could be worng though
Old 09-22-2005, 12:27 PM
Roadstar  is offline
Posts: 451  -  iTrader: (4)
he use the pros in the jem and the blaze in the universe
the pro's sound real good!
Old 09-22-2005, 12:33 PM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Oh my I thought he was already using the Evos at that time .... When does steve started to use the evo???
Old 09-22-2005, 12:37 PM
Flobanez  is offline
Posts: 5,513  -  iTrader: (1)
So do the Blaze.
Old 09-22-2005, 01:13 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
The Steve's Special is basically the 6 string version of the Blaze, so if you want that tone in your 6-banger, there you go.
Evos didn't come out until the early 90s, the same time as the VWH.
Old 09-22-2005, 09:49 PM
dimarzio has the evos listed as coming out in 93 . I'd imagin that steve played with the evolution design a bit before hand so i'd guess he was working with the evo prototype in 92
if i am right on my dates P&W was released in 1997.
So he actually probably did use evos . I thought P&W came out earlier and the evos come out later but i didn't check . till now
Old 09-23-2005, 01:56 AM
Cozi101  is offline
Posts: 260  -  iTrader: (0)
Nope it was the PAF pro's and Blaze. PAW was 1990.
Old 09-23-2005, 02:45 AM
mi2tom  is offline
Yeah... that's why I was wondering the P&W released on 1997????
Old 09-23-2005, 03:14 AM
King Knall  is offline
Posts: 2,445  -  iTrader: (0)
Nah, you could tell that the album still had that 80's/early 90's sound.
Old 09-23-2005, 03:48 AM
Cozi101  is offline
On the topic of PAF pro's, does PAF pro in the bridge position sound different to it in the neck? I mean there's alot of guitars with dual PAF pro's but if it's the same pickup how does it sound different? Or is there another reason they have PAF's in both position that I'm missing?
Old 09-23-2005, 04:01 AM
It does. Basically the neck is the rythm pickup and the bridge is the lead. The neck is warmer, and the bridge is hotter. Vai uses both positions nearly all the time in between his songs.
Old 09-23-2005, 04:12 AM
Cozi101  is offline
But if it is the same pickup, how is moving it 2 inches either which way going to change the sound? What changes it?
Old 09-23-2005, 04:22 AM
ET Guitars  is offline
Posts: 369  -  iTrader: (1)
I thought it had something to do with the physics of the string vibration, amplitude and wavelength, you know all that technical type stuff.
Old 09-23-2005, 04:31 AM
Cozi101  is offline
Yeah but that couldn't have THAT much of a difference.
acoustic guitar, bridge pickup, bridge position, bridge pup, dimarzio pickup, dimarzio pickups, fret guitar, fret guitars, neck pickup, neck position, neck pup, paf pro, paf pros, string tension, tone zone, wiring diagram
Passion & Warfare Jem / graphics or wood? ChristopherWoods JEM and Universe Guitars 24 05-29-2005 12:55 PM
Pickups with Passion and Warfare Max Payne Pickups & wiring 5 12-02-2003 08:09 PM
Effects/Setting of Passion & Warfare SatanicShred Gear and Equipment 5 01-15-2003 11:25 AM
Jem777mc Passion & warfare - new pictures jerrye JEM and Universe Guitars 68 04-04-2002 03:19 AM
passion and warfare swirl coloured FrenchJemlover JEM and Universe Guitars 4 02-18-2002 10:13 AM
