Pickups & wiring
pickup help
Pickups & wiring
09-27-2003, 07:25 PM
woodros
Posts: 303 - iTrader: (
pickup help
hello, i have a breed(bridge), hs-2(middle wired for single coil) and a paf pro (neck) anyway, the other day i noticed that the breed wasnt really working properly, so i opened up the guitar, re-soldered one of the wires (from the breed) back onto the switch, anyway i then noticed that if i pushed on a particular place on the
scratch plate
the signal cut out, the guitar was alright but tonight the breed was playing up again and the tone pot would not control the tone at all, the pickup now sounds weak again. could someone please show me a
wiring diagram
ad dont forward me to dimarzio, the switches on their diagrams are not the same as mine, one final thing and probably most important is that the guitar is an rg550 so the switch is the original one that came with the guitar, not the ones on dimarzio or a multipole, any advice would be welcomed thanx
woodros
Find all posts by woodros
09-28-2003, 11:48 AM
woodros
the guitar is know wired up as per the jem wiring diagram, however the signal is very weak on all the pickups, through tapping the pole pieces with a screw driver you can hear that in the 2 and 4 positions both the full humbuckers and single coil are making a sound rather than the prper way where only one coi of the humbucker works producing a
strat sound
, so i have no idea whats wrong with it. also the tone knob does not function at all.
woodros
09-28-2003, 01:47 PM
woodros
pickups are now functioning perfectly! however when you move the scatch plate the sound cuts out and if you screw the plate back on the signal will cut out, however if you press on the board the sound comes back, can ANYONE reply and tell me what may be wrong seen as though this has had 22 odd views i cant understand why saddo here is the only one replying!
woodros
09-28-2003, 02:02 PM
Ralph khoury
Posts: 451 - iTrader: (
My advice is to make sure the wires arent touching the scratch plate!
Ralph khoury
Visit Ralph khoury's homepage!
Find all posts by Ralph khoury
09-28-2003, 07:12 PM
woodros
yeah so anyway! me and dad fixed that problem, but the thing is the bloody pickups sound all wrong now! the neck is way too loud the breed is now functioning as a single instead of a humbucker!
i used this diagram and figured out the corresponding colours on the dimarzio wires
http://www.guitarelectronics.com/dia...rsal/hsh1.html
thought this would do it but it obviously didnt
can anyone send me a diagram that is SURE to work properly just for reference my guitar is an rg550 and the switch is the one where all the lugs are on one side, the middle pickup is a hs-2 but i want to wire it for single coil sound, surely some of you have done this before. i remember i had problems about a year ago and alot of you told me you'd replaced the pickups in your rg's, so y'all how did you do it!!
woodros
09-29-2003, 02:08 AM
Ibateur
Posts: 2,947 - iTrader: (
Mate, before anything else goes wrong, please take your guitar to a shop with a tech. Have 'em figure it out.
Ibateur
Find all posts by Ibateur
09-29-2003, 08:13 AM
woodros
probably the best idea!
woodros
09-29-2003, 08:44 PM
woodros
i'd just like to say thankyou to everyone who has replaced pickups in their rg's for posting on this thread you guys are the best!
woodros
09-29-2003, 10:29 PM
MicJustMic
Posts: 930 - iTrader: (
Use the diagram on Ibanez.com for the Jem 555, it's the same switch that's in an RG 550 and the
Dimarzio pickups
all have the same color codes.
Make sure you don't bridge any of the lugs with solder, be sure to use proper strippers for the wires and leave only about 1 mm of bare wire, twist those wires ONCE around the lug (makes for easier removal if needed) and be sure your solder joints are proper. (Do a search on the Internet about it if you're not yet proficient with soldering.)
Be sure to ground everything to the same pot (preferably the volume) and I can't stress enough, double check each joint before moving on to the next joint.
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
09-29-2003, 10:43 PM
woodros
thanx very much! one very, very trivial question, the 5 way switch which way does it sit in the plate, i.e. does the compartment with the actual electronics in it face the tone and
volume pots
or face away??
nevermind that doesnt make any sense you could wire it up any way the switch is still going to select the right pickup if you've wired it up to the right thingy etc.
woodros
dimarzio pickup
dimarzio pickups
paf pro
scratch plate
strat sound
volume pots
wiring diagram
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
when to use middle pickup
Evo 2 is the best pickup of all
how to paint a pickup
06:20 PM
