Old 07-15-2006, 01:48 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
pickup leads(wires) why cut them so short?
I have noticed that some people will replace pickups and cut the wires so they barey reach the pickup selector. Even too short sometimes. I have a tone Zone and the wires are too short. I'm going to need to extend the wires.
Why cut them so short? Does it improve the sound or lessen hum, or what? I will cut a little off mine but I leave a good 5 inches in case someone wants to ever use it in the neck position.
john
Old 07-15-2006, 03:49 PM
frankfalbo  is offline
Re: pickup leads(wires) why cut them so short?
No good reason. If you're totally anal you'll say any reduction in signal travel is an improvement, but it's total hogwash. You're going to send it through a 6'-20' cable anyway. 6" in the cavity is irrelevant.
Old 07-15-2006, 04:03 PM
ibanezcollector  is offline
Posts: 3,207  -  iTrader: (29)
Images: 24
I usually try to keep them as long as possible but sometimes you get good deals on short lead pickups cause some people dont want to deal with them
Old 07-15-2006, 04:16 PM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
I don't cut them unless I have too, cause it's easier to sell a pick-up with all of it's wire left.
Old 07-15-2006, 04:40 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
I dont cut them, I either cable tie the excess in a nice loop or I gluegun the spare lengths of cable to the side/bottom of the electrical cavity....
then when you want to change it out !!!
sweet, a full length of cable !
Old 07-16-2006, 06:09 AM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
So so true. Its better to be completely anal about your soldering job if your worried about resistances. Although i can tell the difference between a 6foot and 20 foot cable too :P
Old 07-16-2006, 12:32 PM
john1880  is offline
Good to know. Thanks. Apparently some people feel differently and now I have a Tone Zone with about 1 1/2 inches of wire. Oh well. I can "fix" that.
john
Old 07-16-2006, 02:58 PM
j.arledge  is offline
Posts: 1,804  -  iTrader: (30)
most of the time i just leave my pickups with the full factory lead and just strip the ends off instead of cutting them down . I just take a wire tie and fold whatever i dont need and tie it up .
Old 07-16-2006, 05:24 PM
Jaden  is offline
Yea, I once did the maths on cable length vs signal degradation and didnt even bother math'ing the pup leads !!!
its all bloody millivolts anyway !!! - hardly going to matter if you trim 4" off the pup cable !!!
dont ask me the results cos I cant remember them - I just remember it being a complete waste of time !
Old 07-17-2006, 12:51 AM
That's the best part (also echoing what WIS just said) lots of people can tell the difference between a 6' and 20' cable. I can totally tell. But could I tell between 6' and 6' 4"? No way. That's the difference of cutting down your pickup leads.
Old 07-17-2006, 01:17 AM
john1880  is offline
"6 inches in the cavity is irrelevant". that just sounds wrong in my dirty mind. ;-)
thanks guys. i cut 2 inches off a pickup with lots of lead and soldered it to the tone zone that was butchered. all is well now.
john
Old 07-17-2006, 02:45 AM
TonyT1000  is offline
Posts: 109  -  iTrader: (0)
I have lengthened cut ones, too. Just solder more wire on and use some shrink tubing to make it look neat...
Old 07-17-2006, 11:57 AM
I almost always replace the whole 4-conductor with new cable if it's short. It's just easier that way. Then I get to clean it up and re-tape it.
As for "6 inches in the cavity" yes you have a dirty mind and should be ashamed of yourself. Let's think of it like this: Everyone should have at least 6 inches (of wire) in the cavity.
Old 07-18-2006, 12:07 AM
john1880  is offline
Oh, I dont think I can do that...unwrap the pickup and replace the entire lead. That sounds a little scarey for me.
Yeah, 6 inches of wire in the cavity and everyone is happy!
john
neck position, tone zone
My Pickup wires are too short how can I lengthen them? sniperfrommars1 Pickups & wiring 1 05-24-2004 11:49 AM
Breed bridge PU: describing the mids Ced777 Pickups & wiring 13 04-19-2004 05:49 PM
Pickup adjustment problem. RG-Head Tech: Setup, Repairs and Mods 2 01-29-2004 05:47 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
Pickup Issue.. - Problem with wiring? MrBungle Pickups & wiring 5 04-15-2002 10:03 PM
