Old 01-31-2010, 10:06 PM
CarvinRose  is offline
Posts: 52  -  iTrader: (0)
Pickup not impressing me!!
Hi Guys,
i replaced my stock ESP pickups with dimarzio evo2 bridge and chopper neck keeping the stock esp middle pickup. (HSS)
Honestly i am not getting anything surprising. They do sound louder though. Is it possible that these pickups were wired wrong? Some other factors are:
1. Its esp 103qm ltd
2. I use pod xt and haven't change the tone since changing the pickups.
3. Haven't tried with a bigger amp yet.
Old 01-31-2010, 10:44 PM
elcid  is online
Posts: 8,718  -  iTrader: (12)
Re: Pickup not impressing me!!
Could be any 2, 3 or that you just don't like the pickups.
Just because Stevsus Vaist uses the pickups doesn't mean they will work for you, contrary to popular opinions
Old 01-31-2010, 11:07 PM
corpraider69  is offline
Posts: 311  -  iTrader: (0)
the Bridge pickup on the ESP LTD 103QM is pretty nice it is very full and sounds great with a lot of gain so I can see why swapping it might not have got you the bang for the buck you thought it would sometimes what you have is better than you think.
Old 01-31-2010, 11:27 PM
Ahh thats a shame for me. Hope i can find something good out of this pickup. And yah i use a lot of gain!! i need to learn how to play with low gain.
Old 02-01-2010, 01:58 AM
moonlight  is offline
Posts: 353  -  iTrader: (0)
Maybe it's not the pickups,maybe it's what you are play it through.
Old 02-01-2010, 06:52 PM
Finally i am getting some differences i guess. Stock pickup worked well with high gain but evo2 is more clear. I can definitely feel less hum/buzz now. So i guess it is not a high gain pickup which was my mistake.
Cheers
Old 02-01-2010, 07:09 PM
Manticore  is offline
Posts: 593  -  iTrader: (0)
following these guidelines made a world of difference for me
From The dimarzio web page FAQ;
Does it matter which direction I install my pickup?
Most humbuckers are symmetrical and their sound does not change at all when installed backwards, but some have a slightly different sound if you install them in the opposite direction from normal. It’s not a matter of right or wrong, but a matter of taste for such a subtle difference, if you can hear the difference at all. Those models include the Air Norton™, Air Zone™, Evolution® neck, bridge and 7-string, FRED®, Humbucker from Hell™, DLX Plus™ neck and bridge models, Virtual P-90™, Blaze™ neck and bridge models and Tone Zone 7™.
The Steve’s Special™, the Bluesbucker® and the MegaDrive™ have distinctly different sounds if you turn them around, and there is no ‘right’ installation direction. The Bluesbucker® is brighter-sounding with the adjustable screw coil towards the bridge, while the MegaDrive™ is brighter-sounding with the adjustable screw coil towards the neck. The Steve’s Special™ is brighter-sounding if the coil on the pickup’s cable exit side is toward the bridge.
I have a pickup with adjustable polepieces. What are the adjustable poles for?
Polepiece adjustment is intended to balance the volume between individual strings. The factory setting works for most players. If you don't hear any imbalance between the strings, there's no reason to adjust the poles.
How high should I adjust my pickups for the best sound?
There is no specific distance that works best for everyone. We measure string height from the top of the polepiece to the bottom of the string when the string (usually the high or low E) is held down at the highest fret. For standard, full-size humbuckers, a reasonable starting point for the bridge pickup is at least 1/16" (1.5mm) from the high E and 5/64" (2 mm) from the low E. There are no recommended distances for the other 4 strings. Their polepieces should be adjusted (if necessary) by ear in relation to the volume established for the first and sixth strings. Once the bridge pickup is adjusted to a useful distance, the neck pickup can be adjusted by ear for a good balance.
For single-coil pickups and all hum canceling single-coil replacements with Alnico 5 rod magnets, we’ve found the following formula works very well: at the highest fret (usually the 21st or 22nd), the closest recommended distances from the top of the magnet to the bottom of the string are:
Neck and middle pickups
low E 1/8” (3.2mm)
high E 3/32” (2.4mm)
Bridge pickup
low E 3/32” (2.4mm)
high E 1/16” (1.6mm)
The Virtual Vintage® 2.1, 2.2 and VirtuAL 2® models have low magnet pull, and so do the Virtual T™ and all of the Fast Track™ models, including the Chopper™, Cruiser® and Pro Track™. They can all be adjusted relatively close to the strings. At the highest fret the closest recommended distances from the top of the magnet to the bottom of the string are:
low E 3/32” (2.4mm)
Bridge pickup
low E 1/16” (1.6mm)
high E 3/64” (1.2mm)
These settings will provide a lot of presence and attack. For a more open 1950s sound, try adjusting the pickups 1/32” (0.8mm) further from the strings.
What happens if I adjust my pickup too close to the strings?
The closer the pickup gets to the strings, the stronger the signal that's sent to the amp. However, getting a pickup close to the strings brings the magnetic field closer, too. If the magnetic field is strong enough, it alters string vibration enough to make the guitar sound out of tune, and it can also cause string buzz and reduce sustain.
Old 02-01-2010, 08:32 PM
Whoa big post! thnx man
dimarzio
Stupid pickup question - What if there was no pickup... ashlock Tech: Setup, Repairs and Mods 3 07-06-2001 05:12 PM
Pickup is too tall for cavity - direct mounted pickup tomizm Tech: Setup, Repairs and Mods 8 05-09-2001 06:22 PM
Pickup phase - ..should that neck pickup be upside down? iain Tech: Setup, Repairs and Mods 7 02-14-2001 03:51 AM
