Pickups & wiring
Pickup Output Specs
Pickups & wiring
06-28-2006, 02:08 PM
rrhea
Posts: 263 - iTrader: (
Pickup Output Specs
Hey guys!
I have always wondered what exactly the spec numbers mean on the DiMarzio website. I have various DM pickups in a bunch of guitars, and based on personal experience I have mentally assigned a meaning to an output of "375" vs. an output of "275", etc. But where does DC Resistance come into play? And can you really base the "hotness" of a DM pickup on the output rating, or is it more complicated than that?
Also, how would one compare a Duncan pickup's output with a DM pup based on the specs given on each company's website? The Duncan specs don't have an "output" figure, only DC Resistance and "Resonant Peak".
I am pretty ignorant when it comes to the science of electronics, so I'd like to be enlightened.
Ryan
rrhea
Visit rrhea's homepage!
Find all posts by rrhea
06-28-2006, 03:06 PM
rgr
Posts: 1,791 - iTrader: (
Re: Pickup Output Specs
First, go here,
www.billlawrence.com
, and read Pickupology
There isn't a standardized way to measure output, so, there is no way to really directly compare outputs.
DC resistance is the resistance of the turns of wire around the bobbins, is it a direct way to measure output? No. Usually (not always) higher DCR means more output the tone is more focused in the mids, but different wire guages, magnets, polepieces, etc... can change that. I find that even DiMarzio's tone ratings don't exactly correspond to Duncans. The best thing to do is either try different pickups in guitars and develop are relative sense of how the manufacturers rate the tones.
As a rule (again, a general rule, not set in stone) DiMarzios tend to be more hi-fi, yet compressed sounding, with a lot of mids (although the Steve's Special breaks this rule). Duncans tend to be more raw and vintage-y sounding, and don't have as much mids (the JB does have a spike in it's upper mids, but not in a DiMarzio way). So, coming from using Duncans and looking at the
DiMarzio tone
ratings, you might expect a Norton to be very nasally, but it's not, it's quite open sounding.
Oh yeah, the "resonant peak" on the Duncan chart, usually a higher number means a brighter pickup.
I won't say I hope this helps, but I hope it doesn't confuse the issue too much more...
12:02 PM
rgr
Find all posts by rgr
06-28-2006, 03:35 PM
Demiurge
Posts: 883 - iTrader: (
The whole DC-resistance thing has to be one of the biggest misconceptions regarding pickup output. Years ago I bought a Kent Armstrong "motherbucker," which is two "hot rail" style humbuckers wired together and was listed at 27.5k. Of course, you see most "hot" pickups listed around 13-16k so I bought it, wired it up, and expected it to melt my amp (not literally, but you understand).
Well, it didn't. It had fairly high output, but not more than your average ceramic-magnet pickup. Like it's said in that link in the above post, DC has more about the frequency curve of the pickup. It was a bright pickup that sounds phenomenal in a heavy
Les Paul
-style body (comping the brightness with its density and low-end), though.
Demiurge
Find all posts by Demiurge
06-28-2006, 03:39 PM
JJEMMER777
Posts: 8,374 - iTrader: (
rgr
And to think, to this day, Rog still denies being a rocket scientist
JJEMMER777
Find all posts by JJEMMER777
06-28-2006, 06:16 PM
rgr
You're just trying to blame that Mars lander thing on me, it won't work...
rgr
06-28-2006, 07:42 PM
rrhea
Thanks rgr! That has helped me more than you know. Reading the Lawrence stuff was particularly enlightening.
And now I understand why Duncans and DiMarzios have a certain "sound" that seems to permeate through each model of their respective pickups. I tend to prefer the DM "sound", and you decscribed it perfectly as "hi-fi and compressed".
Thanks again for the info! This is apparently a very, very deep subject that one could study quite a while.
Ryan
rrhea
06-29-2006, 12:13 AM
TonyT1000
Posts: 109 - iTrader: (
Inductance is a more telling spec than DC resistance. And most pickup manufacturers don't disclose it.
TonyT1000
Find all posts by TonyT1000
06-29-2006, 10:00 AM
Shredder87
Posts: 417 - iTrader: (
The best way to tell the difference is to plug in and play!
Shredder87
Visit Shredder87's homepage!
Find all posts by Shredder87
06-29-2006, 12:07 PM
rgr
rrhea
Glad I could help! Bill definitely knows his stuff!
rgr
dimarzio tone
les paul
RG2610 one pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
how measure guitar specs
Ibanez Factory Pickup Output Ratings?
Big Red
01:59 PM
Anyone Know INF pickup specs?
lyconxero
Pickups & wiring
03:28 PM
Parker Fly owners, pickup info.
bammbamm
Pickups & wiring
10:35 AM
Measuring pickup output - Particularly IBZUSA C1 & C2
JESTER700
Tech: Setup, Repairs and Mods
08:54 PM
Can you lower the output of a pickup ? - Voltage reduction ?
6828
04:03 AM
02:02 AM
