Pickups & wiring
Pickup Problems
Pickups & wiring
01-08-2009, 07:04 PM
aarontheguy3000
Posts: 18 - iTrader: (
Pickup Problems
Let me just start off by saying I'm an idiot. I recently uninstalled some old infinity
pickups
as well as a crackly volume pot from my
RGT42
. I bought some new Breed Pickups as well as a new volume pot thinking that it'd be no problem to do myself.
Unfortunately, I'm having a little trouble. For some reason both the bridge and neck pickup sound in all 5 selector settings. I don't know if the ground wires from the pickups have to be in a certain place, or if I rewired something else weird when I put in the new volume pot. Does anyone know what might be wrong here?
Thanks
aarontheguy3000
Find all posts by aarontheguy3000
01-08-2009, 08:06 PM
callen3615
Posts: 1,412 - iTrader: (
Re: Pickup Problems
Its not the ground......
callen3615
Find all posts by callen3615
01-08-2009, 10:29 PM
Foulacy
Posts: 354 - iTrader: (
Re: Pickup Problems
chances are you wired it wrong. if you just matched the colors of the old wires to the new ones, the pickups probably have different hot, series and ground colors.
Foulacy
Find all posts by Foulacy
01-09-2009, 08:58 PM
aarontheguy3000
Re: Pickup Problems
Thanks for the help but maybe this is one job I should leave to the experts. Hopefully, I didn't rewire it beyond repair. Maybe they can do some mod work and turn it into a toaster?
aarontheguy3000
01-09-2009, 09:34 PM
LuredMaul
Posts: 764 - iTrader: (
Re: Pickup Problems
http://www.ibanez.com/support/wiringdiagrams.aspx
LuredMaul
Find all posts by LuredMaul
01-17-2009, 09:16 PM
aarontheguy3000
Re: Pickup Problems
Thanks, I actually brought that diagram to the tech when I gave him the guitar last week. Unfortunately, he's having just as much trouble as I did.
The tech I gave it to works for a very respected music store in my city, so I assume he's good at what he does. It's just he started working on the thing on Monday, and now it's Saturday, and he still hasn't figured it out... He thought he could get it if he replaced the 5-way switch, but still no luck. I need the guitar soon, so I really can't wait much longer. Plus I'm worried this is gonna cost me an arm and a leg.
Anyone ever replace pickups in an RGT42? Should I try to contact Ibanez or maybe Dimarzio for some tech support?
aarontheguy3000
01-17-2009, 09:25 PM
moebius
Posts: 2,041 - iTrader: (
Re: Pickup Problems
Take it to someone else. Armed with the
wiring
diagram and the dimarzio instructions for pickups (to get the wire color codes) a decent tech should be able to fix it. Do you have the correct 5-way selector?
moebius
Find all posts by moebius
01-17-2009, 09:47 PM
LuredMaul
Re: Pickup Problems
I have done many swaps on RGT42's it looks harder than it is
LuredMaul
01-17-2009, 10:41 PM
aarontheguy3000
Re: Pickup Problems
LuredMaul
Cool man, maybe you could help me out here. I know the Infinity has different colour coding than the Breed. But would the Breed still have the "standard" Dimarzio wiring functions (black and white together, red hot, green and bare ground)? I'm kind of an amateur when dealing with this stuff so cut me some slack. But the red's from the two Breed's would wire to the volume pot, and the greens and bares would go into the 5-way in some order? Any more help would be awesome!
Thanks,
Aaron
aarontheguy3000
01-17-2009, 10:51 PM
callen3615
Re: Pickup Problems
That guy doesnt know what he is doing. Take it to another guy, or do what i do. I screw with it until it works. Plug in your guitar and touch the wires against the back of the switch until you figure it out, never failed me.
PS:The hot on dimarzios are the wires you had to bind together.
callen3615
01-17-2009, 10:54 PM
callen3615
Re: Pickup Problems
My rgs have always had the hot from the bridge on the top thingy on the switch. (the one closest to the neck)
callen3615
01-18-2009, 12:17 AM
aarontheguy3000
Re: Pickup Problems
callen3615
Awesome, that's what the diagram shows as well. Thanks.
callen3615
The one's I binded together? You mean the black and white wires? I thought those were just supposed to be soldered together and taped off.
Thanks for the responses. Man, I wish that music store was open tomorrow.
aarontheguy3000
01-18-2009, 04:11 AM
aarontheguy3000
Re: Pickup Problems
Courtesy of tech@dimarzio(dot)com. Honestly, they responded so fast!!!
"For Infinity and Power Sound 2-conductor Ibanez pickups, the red wire from any DiMarzio humbucker is the same as the white wire from the Ibanez pickup. Our black and white wires together are the same as the Ibanez red wire. Our green and bare wires together are the same as the Ibanez bare (ground) wire, which is usually soldered to the back of the volume control."
Thought I'd post it in case any of you other poor souls ever need it. Thanks again everyone.
aarontheguy3000
01-18-2009, 04:20 AM
LuredMaul
Re: Pickup Problems
the bridge connects just like any other bridge. red to the power where the old wire was removed green and bare to ground white black together and to the other side of the switch for splitting.
It's the neck position that is different
the black and white are not soldered together on the neck.
the red on the neck is still to the power.
the bare is to ground and green to ground
the white is to the last terminal and the black to the terminal that has the jumper wire.
I'm doing this from memory so I may be wrong on the black and white bridge terminal and the white from the neck terminal they may actually be reverse.
you should be able to tell better once your looking at how it's wired from the factory.....replace one pickup at a time to keep it straight.
LuredMaul
01-18-2009, 05:17 AM
aarontheguy3000
Re: Pickup Problems
This kind of differs from what Dimarzio wrote, yet I seem to trust yours more. The Infinity has two wires (coincidentally black and white) that are connected in the bridge, but not the neck. And your explanation uses the same wiring with the Dimarzio pickups. Damn, I wish I had my guitar here! Thanks though.
aarontheguy3000
breeds
pickups
rgt42
wiring
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
when to use middle pickup
Evo 2 is the best pickup of all
how to paint a pickup
Jem555BK Pickup Problems
j3yps
01:39 PM
Problems with EMG 85 pickup installation
LonePhantom
Pickups & wiring
06:03 PM
EMG pickup problems? Any help appreciated
TheShaman
Pickups & wiring
11:40 PM
Bored? Help Me Out With My Pickup Problems
shredmaster26
Pickups & wiring
07:26 PM
Pickup problems?
BucketBot
Pickups & wiring
03:55 PM
11:31 PM
