If your problem is that the old screws are too fat to fit through the brass rings fitted in the EMG, then you can put a screw into the EMG, then heat the screw with a soldering iron until the heat transfers to the bushing, and it will come out, leaving a larger hole. The ring can usually be put back the same way, but may require a little superglue.
