Pickups & wiring
Pickup Screws...Are they all the same
Pickups & wiring
10-29-2007, 12:44 PM
lazz
Posts: 8 - iTrader: (
I just picked up a
Tone Zone
from a member here that Im trying to put in my RG550. I did not get any screws with it so Im trying to use the stock Ibanez screws which are not fitting. Is this typical?
lazz
Find all posts by lazz
10-29-2007, 01:33 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
Re: Pickup Screws...Are they all the same
yup. ibanez are bigger. the dimarzio and duncan screws are the same size. sorry to hear about the bad luck. i always send pickups out with new screws just in case.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
10-29-2007, 03:08 PM
rgr
Posts: 1,791 - iTrader: (
Ibanez uses metric screws, DiMarzio and SD use "standard" threads, I think they are 3-48 but I'm not positive.
rgr
Find all posts by rgr
10-29-2007, 03:09 PM
ibanezking
Posts: 531 - iTrader: (
Ibanez are generally M3
Dimarzio and Duncan a M2.5
Max
ibanezking
Visit ibanezking's homepage!
Find all posts by ibanezking
10-29-2007, 05:13 PM
Jaden
Posts: 2,464 - iTrader: (
if it helps, you can get an M3 tap and widen the hole quite easily without the need to drill.
as long as you are resigned to having M3 holes in your Dimarzio pup.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
10-29-2007, 06:11 PM
-Rhaab
Posts: 479 - iTrader: (
I used the screws on my old ibanez pickup (philips type), it took a little more force to twist them in but they opened up and it goes smoothly now. I don't like the screws that came with my
dimarzio pickup
, the flathead type screws cause it kept slipping and it was annoying.
-Rhaab
Find all posts by -Rhaab
10-29-2007, 07:15 PM
rgr
You basically retapped the hole, but that is not the recommended method.
rgr
10-29-2007, 08:15 PM
TheToneZone
Posts: 209 - iTrader: (
Dimarzio ships....
Mike
TheToneZone
Find all posts by TheToneZone
10-30-2007, 12:29 PM
lazz
TheToneZone
Dimarzio ships....
Mike
Exactly...After calling a few places with no luck I called Dimarzio and asked them if I could just order a set from them. The tech I was talking to said "no problem I'll just send you some"...I know its just a set of screws but a Big thumbs up to Dimarzio, there are other companys out there that I know would not have done that...and yes even for a sh*ty set of screws! Thanks for the help guys.
lazz
10-30-2007, 09:38 PM
ryanb
Posts: 1,457 - iTrader: (
^^ Yeah, DiMarzio is pretty good in the customer service department. A lot of other companies need to learn a lot from them.
ryanb
Find all posts by ryanb
dimarzio pickup
tone zone
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
Problem w/ bridge pickup on my JEM90HAM: as singlecoiled !
nmanel
Pickups & wiring
01:33 AM
HELP REQUIRED - Total novice trying to fit a pickup!!!!!
SPENSPUMA
Pickups & wiring
12:24 AM
Direct mount pickup screws
taracatac
11:00 PM
Pick up screws
Magnafury
Pickups & wiring
10:33 PM
Stupid pickup question - What if there was no pickup...
ashlock
Tech: Setup, Repairs and Mods
05:12 PM
05:24 AM
