Pickups & wiring
Pickup wiring help!, cheers :)
Pickups & wiring
11-11-2007, 10:26 AM
synth002
Posts: 43 - iTrader: (
Hey all, this is only my second post but Im gonna just jump right in lol!
Soo!... last night after a fair amount of research I brought myself a Dimarzio EVO2 and
EVOLUTION Neck
.. BUT! now I have a problem, I currently have a nasty EMG81 living in my guitar atm (no
neck pup
atm!) so I know(well I think I know!) the electronics/pots ect need to be changed for the new pickups because of going from active back to passive..
My plan is to have the following..
3-WAY Switch
1x500K push/pull pot
1x500K pot
(still have my old passive style jack input)
With any luck the 3 way will give me a Bridge-Middle-Neck setup and I will be able to split the coils on these settings using the push pull pot.. (I would use a 5-way but I can imagine it being that little bit more fiddley when playing live! more than a push/pull pot anyways!) So to start with, am I right in thinking I can have the above setup fitted to my guitar?! or am I jut a crazy man lol.
Also I have found a place where I can get the items (online in the UK) but will I need to also purchase capacitor(s) & wire(s) ect?? If so could some one in the know let me know exactly what I need if possible!!..
Last thing I want is to get the pickups n pots ect run to the guitar repairs bloke and have him tell me he can't fit it with out such n such part y'know!
Thanks very much for any help!!!! really means a lot!
Cheers, chris
synth002
Find all posts by synth002
11-11-2007, 12:47 PM
LuredMaul
Posts: 764 - iTrader: (
Re: Pickup wiring help!, cheers :)
A 5-way switch is hella less fiddley than a 3-way and push pull pots, but, you will get more wiring options with what you have picked out...
LuredMaul
Find all posts by LuredMaul
11-11-2007, 01:26 PM
synth002
I spose you could be right but I think for my style it would be better to use a push/pull pot.. maybe lol, plus I guess it would have more switching options doing it the way I mentioned which is good as I want my main gee-tar to be as versitile as possible!. Do you know what kind of capacitor(s) ect I would need to get for the setup mentioned above, the pickups with be with me by mid week so my plan is to have them installed before the weekend so I gotta have all the parts ready to go for a gig test at the weekend!
synth002
11-11-2007, 01:35 PM
Wild_Child
Posts: 681 - iTrader: (
Reviews: 3
I don't think it would be less fiddly. What if you wanted to go, for example, from a coil split
neck pickup
, to the full
bridge pickup
? If you had a 5 way switch, you could flick it to the first position from the 4th position in one flick. With your way, you'd have to push in the pot AND flick the three way to the first position.
What extra switching options would it give?
Wild_Child
Visit Wild_Child's homepage!
Find all posts by Wild_Child
11-11-2007, 01:43 PM
synth002
hmm maybe you guys are right! I suppose the only extra switching option would be to have would be having the middle position with the coils split, perhaps I should just stick with the 5-way I have and get 2 new pots after all!
synth002
11-11-2007, 02:20 PM
Vim Fuego
Posts: 908 - iTrader: (
just to throw a spanner in the works, what you suggest sounds like the circuit of a JS1200, try
http://www.ibanez.com/support/wiringdiagrams.aspx
I guess if it's good enough for
Joe Satriani
you might do ok!
What are the electronics like now? does it already have a slot for a 5 way? If not it's easier to drill a simple hole for a 3 way!! At least, that's my opinion!!
the JS has a 0.022uF capacitor on the tone and a further 330pF capacitor which is switchable on the volume. I think to correct for sone of the tone roll-off when turning the volume down. The Jems have one all the time I guess Joe wanted it switchable.
Jim
Vim Fuego
Visit Vim Fuego's homepage!
Find all posts by Vim Fuego
11-11-2007, 05:40 PM
synth002
AHH! Confused!... okay I have thought about it for a while and im just gonna keep the five way in there atm for this config...
neck(hum)
neck(single coil)
DONT KNOW - What would you do, both humbuckers or both single coils???
bridge(single coil)
Bridge(hum)
So yeh Im keeping the 5-way in there now lol and just getting 2 new pots! Could someone in the know please tell me what capacitors im going to need! As I need to order the pots and capacitor(s) asap so it's all ready to go when the pickups arrive!
thanks a lot!, chris
synth002
11-11-2007, 06:17 PM
Wild_Child
Reviews: 3
Have you considered switching between parallel and series on the neck pickup?
Wild_Child
11-12-2007, 07:33 AM
Vim Fuego
A bit of advice (hopefully) Wild_Child suggested you try using a 5 way switch and switching the neck HB between series and parallel (like on a two pickup RG1527). I tried to answer a similar thread on this and found that I couldn't understand the Ibanez diagrams showing this with what looked like a simple 5 way switch. I usually can understand these things (having a degree in physics) but it was too much for me!! I came up with a circuit using the VLX91 switch as used in the Jem guitars but not with a regular 5 way... you may find this option difficult if you don't get the right switch or understand the diagrams. (Alternatively if you can understand the Ibanez diagrams please explain them to me!
If I have a revelation I;'ll let you know!
Jim
Vim Fuego
11-12-2007, 10:36 AM
synth002
Thanks for the replies guys.. I have seen some guitars having switching from series to parallel but im not too sure what the actually does!! how is it different from switching from humbucker to single coil?
I really am a noob when it comes to guitar electronics! Only reason im trying to figure out the best setup for me is because of the change of pickups & the fact I have to change out the pots ect because of going from active back to passive and it just seems like I should make the most out of the change..
synth002
11-13-2007, 08:15 AM
Vim Fuego
A humbucker is really two single coil pickups wired in series.
If you have north poles on one coil and south poles on the other and you wind one coil clockwise and one anticlockwise, the signals will add up but any hum will be out of phase in each coil. This reduces the hum generated by the pickup.
There are two things that define the tone of a humbucker compared to a single coil:
1) the resistance (strictlly impedance) of the windings, two coils more resistance - less treble.
2) the presence of two poles per string sensing the string vibrations - less treble.
A
coil tap
will effectively remove one coil of the humbucker from the circuit. Therefore you will have less resistance and only one set of poles sensing the string. This will give a more single coil like sound with more treble but will no longer remove hum.
If you wire the coils in parallel then it's like having two single coils very close together. The resistance of the pickup is reduced so you get more treble but you still have the two sets of pole pieces sensing the string. The advantage is it still reduces hum but the sound is somewhere between the coil tap sound and the
humbucker sound
Of course many other things influence the sound of pickups like magnet type, winding method etc. and some humbuckers have a different sound from each coil so it depends which one you tap.
Jim
Vim Fuego
bridge pickup
coil pickup
coil split
coil tap
dimarzio evo
evolution neck
humbucker sound
joe satriani
neck pickup
neck pup
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
Dimarzio pickup wiring
Van-Hannam
Tech: Setup, Repairs and Mods
10:44 PM
wiring my pickup correctly (b.Lawrence)
choubix
Pickups & wiring
09:14 PM
Building wiring scheme with 3 hums
dope_maggot
Pickups & wiring
04:06 PM
jem pickup wiring HELP!!!
dspires60
Pickups & wiring
12:32 PM
Parker Fly owners, pickup info.
bammbamm
Pickups & wiring
10:35 AM
04:20 PM
