Old 09-02-2003, 05:59 PM
stratman219  is offline
Posts: 283  -  iTrader: (0)
Push pull pots or mini switches?
I'm going to get my DBK rewired so that the hums split. I would prefer the push pull pots but I think the trem arm will end up hitting them. Am I able to split the neck and bridge hums on just the tone pot?
If I get the mini switches, I will put them between the two pots, that seems like a good place. I found some switches that were on/off/on and on/on/on. What are the differences in these? and if there is more than one on position, does that mean I can have either the lower or upper coil on?
Thanks in advance
EDIT: I also saw a switch that was on/off/on and it was also on/on/on. Whats the difference in all these?
Old 09-02-2003, 06:44 PM
EKG  is offline
Posts: 2,280  -  iTrader: (0)
You should be able to use the Tone as the coil split. I don't think it will interfere at all with the trem arm.
I'm not too familiar with the switches, so I won't comment on those ;-)
Old 09-02-2003, 07:10 PM
steve  is offline
Posts: 590  -  iTrader: (4)
As long as the push/pull pot uses a DPDT switch - easily identified by the switch body sticking off of the pot having 6 solder lugs - then you can have that one pull-switch shut off a coil on both humbuckers.
Switches; an on/on/on can allow for more tonal variations, but it gets more complex, and doesn't allow for coil selection... and remember, that can have an undesired effect when combined with the middle single, as choosing the other coil on your humbucker in parallel with the middle single coil will then be out of phase, and also NOT humbucking...
Have a look here, and back up to the main directory, and you'll find other wiring diagrams.
DiMarzio wiring document(s)
Happy hunting.
Old 09-02-2003, 10:26 PM
Thanks guys. I'm getting these done when my pickguard comes in. The pickguard on my DBK had a huge arc on it, so I get a new one under warranty . The tech said that its on its way. I'll see what kind of stuff the tech has and what he can do with them.
thank you
Old 09-02-2003, 10:44 PM
Scott of Actual Time  is offline
Posts: 363  -  iTrader: (5)
Re: Push pull pots or mini switches?
these are 3 position mini-toggles that have an extra middle position. in on/off/on, the middle position is completely off, no switch lugs are connected to each other at all. in on/on/on, the middle position is connected to one 'half' of each side of the switch, sort of halfway between the other two positions if you think about it.
people often use the 3 position mini-toggles to wire lots of phase switching for one humbucker, which can get really complicated without a whole lot of return, IMO. one DPDT push/pull pot will cut both your humbuckers, it'll be way under the trem arm, and that's a good way to start learning about coil cutting and wiring.
Old 09-03-2003, 05:03 PM
bammbamm  is offline
I would avoid using mini toggles personally, just to retain the original look of the axe. Using a pull pot would retain the look of your axe and give you the functionality you're looking for.
Bamm
bridge hum, coil split, mini switches, mini toggle, trem arm, wiring diagram
