Old 09-03-2008, 12:03 PM
Metallion  is offline
Posts: 168  -  iTrader: (0)
Question
PUSH-PUSH Pot with minimal move
Looking for a 500 Push-Push or Push-Pull Tone Pot that has a smaller push-movement than 4mm, maybe 1-2mm.
Anyone knows?
Old 09-03-2008, 07:13 PM
j.arledge  is offline
Posts: 1,804  -  iTrader: (30)
Re: PUSH-PUSH Pot with minimal move
have you considered installing a DPDT mini toggle instead of a push-pull pot? Or prehaps you can upgrade your switch to give you what you want. Maybe even a new set of knobs ? If the shaft fits into the knob further then it wouldn't be as far to pull the pot .
Old 09-04-2008, 08:32 AM
Doing a JEM FP body and want optimally no extra clutter, but extended pickup combination options.
Old 09-04-2008, 08:56 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Thought about using a fender S1 switch? I hear that they are available as a spare these days.
Old 09-04-2008, 04:00 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
or you could get a push-push knob so it's more like an on off switch
Old 09-05-2008, 10:55 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
I never liked the push-push as you could forget which position it was in and can't tell by looking. What extra sound are you looking for(maybe there's another way to get it)? I never use the tone knob so I sometimes use that for other things. It could be used to roll off one coil on a humbucker, or use it to blend in the middle pickup while a 3 way switch selects bridge-neck or both so you could add the middle to either or have all 3 pickups going(you would not be able to get just the middle). Just tossing some ideas out to get you thinking.
Old 10-02-2008, 06:22 PM
Push-Push or Push-Pull, both have too long movements to shift position/connection.
Maybe some super-mini-ceramic 3mm diameter switches are available?
mini toggle, push/pull/ tone pots
push/pull pots Dreamsower Tech: Setup, Repairs and Mods 0 08-14-2007 05:41 PM
Wiring push/push pot and Soldering Kit Question.. jclogston Pickups & wiring 2 02-20-2006 10:59 PM
Fender S-1 switch and push/push pot questions shredfingers Pickups & wiring 1 01-15-2004 12:03 PM
Where to buy a push/push pot? cocobig Tech: Setup, Repairs and Mods 4 09-19-2002 07:00 PM
Need help with push/pull pot, please? Fabe Tech: Setup, Repairs and Mods 9 07-05-2002 02:35 PM
