Pickups & wiring
Replacing v7 and v8 in RG505
Pickups & wiring
03-01-2007, 05:02 AM
bloodandtears
Posts: 392 - iTrader: (
I find the stock pups have no sustain, and i have two pink
paf pros
that i hope will blow the stock pups to bits.
Is it a straight replacement or are the v7/8 pups only two core lead?? if so i guess i'll need a wiring diag? will i need to alter the single coil wiring??
bloodandtears
Visit bloodandtears's homepage!
Find all posts by bloodandtears
03-01-2007, 09:10 AM
_FR0D0
Posts: 528 - iTrader: (
Re: Replacing v7 and v8 in RG505
v7/8 are three core, paf pros are four core.
to replace your Vs wire like this: white+black =
coil tap
, red = hot, green = ground.
That will make the trick
_FR0D0
Find all posts by _FR0D0
03-02-2007, 06:52 AM
RG550BW
Posts: 73 - iTrader: (
I tried same with RG550. It's simple. Go on Dimarzio site,pick humbuckers,pick
paf pro
,pick instalation,pick humbucker-single-humbucker and connect paf pros accordingly..leave single the way it is..it will work.
RG550BW
Find all posts by RG550BW
03-02-2007, 09:36 AM
bloodandtears
cheers.. had a go last night but i found the v7 mounting screws are too big for my paf pros :-(
gotta source them now..
bloodandtears
coil tap
paf pro
paf pros
floyd rose tremolo comes off hinge points when replacing strings
replacing 12ax7a tubes how to
how to replacing a truss rod
how to set up guitar after replacing pick ups
when do frets need replacing
Report: Replacing V7 / V8 with Duncans using VLX91
Alnico5
Pickups & wiring
01:29 PM
Replacing my RG7420
czw
Other 7-string Guitars
12:48 PM
Replacing dots - how?
satch
Tech: Setup, Repairs and Mods
01:14 PM
Mark IV, replacing the tubes. Opinions? - It has 2 EL34's an
trapzilla
Gear and Equipment
12:31 PM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an
floydJ
01:59 PM
11:17 PM
