Old 11-12-2007, 08:54 PM
apb1215  is offline
Posts: 9  -  iTrader: (0)
rewiring problems...please help!
hello all, i recently made several modifications to my ibanez gsa60, and so far have been unable to rewire it successfully. i am trying to one by one eliminate all potential problems, but i just can't seem to make any headway on this.
i followed this diagram exactly, using the fender-style 5-way switch:
http://www.dimarzio.com/media/diagrams/C.pdf
unfortunately, when i powered it up, its very obvious that something is wrong. it does produce sound, but extremely faint sound with no distortion, even when my distortion and volume are cranked to the max. sometimes it just cuts out completely. i was only once able to achieve a somewhat distorted tone, but it too cut out and now after more fiddling around, i can't get anything.
i am an amateur with a soldering iron, but i have checked my connections so many times that i know they should be good enough to at least carry a signal. i do have a suspicion what is causing this though. among other things i did, i repainted the guitar. i painted directly over all the cavities, including the pickup cavities and the wiring cavity on the back. i now recall that these were covered in a clear glossy paint. would altering the consistency of the surrounding paint somehow affect the wiring? i know people get their cavities covered in a shielding paint, but i thought that was just to reduce hum, and would not cause no sound to be produced.
if anyone is willing to help me with this, i would be so grateful, its killing me that i've been without my guitar for almost a week now! i can provide some pictures if anyone would like to see. thanks.
Old 11-12-2007, 10:21 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
Re: rewiring problems...please help!
I'd like to see some pictures, because if you're using that diagram, and all of your connections are solid, you should have no problems.
What kind of pickups are you using? Is everything grounded? Different pickups can make a big difference. With some pickups, the casing mesh around the wire is actually the ground, and some people forget to solder it to a pot and it can lead to these types of problems.
I once had a problem with hum and noise, and I turned off my computer monitor, and it magically went away. Remember this could be contributing to the problem you're experiencing.
I know for a novice this might not be an option, but an ohmmeter is an invaluable tool for electronics work.
Old 11-12-2007, 10:28 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
You probably have some wires touching each other that shouldnt be or shorting out on some other metal part.
Old 11-12-2007, 11:11 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
Without seeing anything it's all a guess, take a break .......walk away and go back to it in about 15minutes.
Now think.... is the output jack soldered backwards??????
Is there two wires touching that shouldn't be??? ( only thing touching another wire should be White/Black pickup wires and ground wires)
Go back and wire just one pickup until it works then add another and so on....you'll find it.........
Oh and of course it's usually the most obvious thing wrong in the world too
Old 11-13-2007, 12:13 AM
apb1215  is offline
thanks for the replies guys. i went ahead and snapped a few pics, i uploaded them to a google photo album here: http://picasaweb.google.com/adamrox/Guitar
once you click on the pics, hit download photo and you can open it up to full resolution to see the details as close as possible.
couple things:
-pup setup is EVO neck, stock IBZ single coil middle, EVO bridge
-guitar was originally a gsa60, i repainted it and converted the single coil neck pup hole to a humbucker size hole
-switch is replacement Fender switch, standard 5-way setup
-that extra connection in between the tone/volume pot holes is a killswitch (which i installed previously, and has worked flawlessly)
-you can see from the pics that the cavities no longer have that glossy finish, which i have come to find out is conductive shielding paint...but i don't think the lack of proper shielding should prevent the signal from even properly transmitting
thanks again to anyone who takes a look. really want to get this baby up and running again!!
Old 11-13-2007, 12:16 AM
apb1215  is offline
also...my friend has a voltmeter that i'm gonna have to try to borrow from him if i can't get this figured out. never used one outside of physics 2 lab before, but it seems like it would help solve the problem pretty quickly.
Old 11-13-2007, 07:12 AM
CosmicDebris  is online
Posts: 3,216  -  iTrader: (4)
I can't tell cause I am old and need glasses but in pic 2 of 4 is that a red wire soldered to the back of the pot?
Old 11-13-2007, 07:30 AM
elcid  is offline
looks like a white wire is going to the back of the pot too
Old 11-13-2007, 03:41 PM
apb1215  is offline
yeah,i kind of ran out of wire, so i used whatever i had to finish wiring, so it isn't correctly color coded...but all the wiring still should follow the diagram correctly
Old 11-13-2007, 05:41 PM
apb1215  is offline
that wouldn't somehow affect the signal would it?
distorted tone, evo bridge, neck pup, pickup cavities
Shoulder problems - help! Eddie88 J-Custom, USA Custom & Prestige Ibanez Guitars 14 05-29-2007 10:41 AM
Any problems with the JS1200 CA original from Ibanez?? greggmetal JS (Satriani Model) Ibanez Guitars 20 10-07-2005 08:48 PM
Problems with EMG 85 pickup installation LonePhantom Pickups & wiring 12 08-23-2005 06:03 PM
new trem problems...from a different perspective btweensunandmoon Tech: Setup, Repairs and Mods 11 05-13-2003 12:47 AM
Problems with Rivera TBR-2SL Tube Head vaijem777 Gear and Equipment 6 04-14-2003 01:24 PM
