Old 04-13-2009, 03:01 PM
nsabino  is offline
Posts: 463  -  iTrader: (0)
Question
Rewiring Question
Hi, I'm gonna change the switch, pots and caps an my RG. I have one thing that I need help with though, well my questions are the following:
1. Can I twist together all of the ground wires from all of the pickups, output jack, tone pot and one that's grounded underneath the middle pickup and solder them to the volume pot?
2. If I can do the above should I also solder to the same solder joint the wire that's grounded to the tremolo claw?
thanks in advance for your help,regards
Nelson
Old 04-13-2009, 03:13 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
Re: Rewiring Question
YES!..........................
Old 04-13-2009, 04:16 PM
nsabino  is offline
thanks
Old 04-13-2009, 04:21 PM
rublalup  is offline
Posts: 98  -  iTrader: (0)
Images: 5
dont advice on doing that...if you want/need to change a pu in the future it would be harder b/c of all that wires soldered together
Old 04-13-2009, 06:44 PM
nsabino  is offline
so what you're saying is that it doesn't matter really. The ground wires don't have to be all together, right? Thanks for the info guys, regards
Nelson
Old 04-13-2009, 07:17 PM
skins345669  is offline
Posts: 835  -  iTrader: (0)
Nelson
Yeah, as long as they start where they should, and get wired to the right ground point, you're fine.
Old 04-13-2009, 07:35 PM
nsabino  is offline
Hi, this is probably my last question before I solder tomorrow everything in one shot and here it goes. I'm thinking of soldering all the ground wires from pickups, output jack ground, a grounded wire that comes from the middle pup cavity and the ground wire that's connected to the trem claw all to the volume pot, also a wire from a grounded cap on the tone pot to the volume pot. In your opinion does this sound ok?
Thanks,
Nelson
Old 04-13-2009, 07:44 PM
Sounds fine.
Old 04-14-2009, 02:00 AM
forest4  is offline
Posts: 167  -  iTrader: (0)
I agree, a ground is a ground... but 'RUBLAUP' is right. You should spread them out, even if it's just two places on the same pot.
Old 04-14-2009, 02:01 AM
forest4  is offline
Sorry, RUBLALUP.
Rewiring RG bLYNDcYDE Pickups & wiring 1 05-02-2008 01:15 AM
Help with Rewiring my RG Optiquest Pickups & wiring 4 02-14-2005 09:03 PM
Ibanez JPM Rewiring teof Pickups & wiring 0 06-13-2004 03:34 PM
rewiring The Madness Here Tech: Setup, Repairs and Mods 0 08-20-2003 10:52 PM
Rewiring a Jem like a JPM lhrocker Pickups & wiring 1 05-28-2002 10:39 PM
