Old 08-04-2008, 06:51 PM
ThomasDJ  is offline
Posts: 5  -  iTrader: (0)
RG1527 noise machine!!! please help..
Hi everyone,
I've got a RG1527 that produces a lot of electrical noise/hiss! ..I've tried to resolder everything twice and shielded the pot cabinet with thick grounded aluminum foil! I've also added a thick ground wire going from the trem, through the pots and to the jack. The noise changes with the 5 way switch. If I touch the strings, the noise decreases. If I turn the tone pot in bass position, the noise also decreses/becomes "darker".
It's not the amp, - I've tried other guitars and other amps etc.
Any suggestions how to solve this?
Thanks
Thomas
Old 08-04-2008, 11:18 PM
Tubarão Guitars  is offline
Posts: 3,965  -  iTrader: (0)
Images: 3
Re: RG1527 noise machine!!! please help..
rewire maybe?
luck.
Old 08-04-2008, 11:24 PM
alecmm61  is offline
Posts: 548  -  iTrader: (0)
Images: 6
i had the same problem i had a bad tone pot get that checked out.
Old 08-05-2008, 05:45 PM
ThomasDJ  is offline
Hi Friends, thanks for your replies.
I've tried rewire everything and did change the pots, but didn't helped.
I've also tried to solder the pickups directly to the jack, which didn't helped. So I guess it has to be the pickups..
Thanks
Thomas
Old 08-05-2008, 06:44 PM
alecmm61  is offline
Images: 6
is it possible you have a bad cable?
Old 08-06-2008, 05:20 AM
ThomasDJ  is offline
Hi Alec,
The cable is ok. I've tried different guitars.
Thanks
Thomas
Old 08-06-2008, 05:49 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Agreed with rewiring and please do not shield with thick aluminium foil you'll lose all your high that way and the guitar will sound unnatural.
Old 08-06-2008, 07:07 AM
ThomasDJ  is offline
Hi Mi2tom!
I've tried to solder the pickups directly to the jack, which do not help. Could it be that the pickup cable are somehow damaged?
Thomas
Old 08-06-2008, 09:00 PM
lebo  is offline
Posts: 9  -  iTrader: (0)
hi,i once had a problem with noise but it was becouse elctric cable which is pluged into 1 el.pluger which has too many electical stuff plug in it(stereo system,2 pc,speakers,lamp,guitar procesor,amp),and when guitar cable touches ground noise from amp is very very annoying
Old 08-07-2008, 12:30 AM
mi2tom  is offline
I'm not very good at explaining things in words, I suggest you taking it to a guitar tech asap!
Old 08-12-2008, 05:18 PM
JohnnyRG1527  is offline
Posts: 99  -  iTrader: (0)
you sometimes get noise when your jack lead crosses over a power cable, say for an effects pedal... could be that?
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 09:00 AM
Drum Machine RG462 Gear and Equipment 0 06-23-2007 01:36 AM
I'm in need of a time machine life is pain JEM and Universe Guitars 12 09-30-2006 12:28 AM
Best Drum Machine? MorbidAngel Recording Studio 16 11-06-2002 01:08 PM
noise - ringing noise chip james JEM and Universe Guitars 6 01-15-2001 08:08 PM
